Sower
Sower's Avatar
01.05.2009, 02:08 PM
I have had excellent success with plastic spurs too. But by the look of the pic the motor is adjusted all the way close to the spur and the mesh still looks a bit loose to me. Maybe not, but that is what I se in the pic. He is most likely using the 44t spur, so the 46t may help with the mesh issue.
Totally agree - this seems like it can only be a mesh issue. Assuming nothing is binding in the drivetrain. Even then, I would imagine the motor would power through it and the drivetrain issue would end up breaking something in the drivetrain rather than strip the spur.
MBX6T Tekin RX8 5s Neuenergy
www.robsower.com
tha5150
tha5150's Avatar
01.05.2009, 02:26 PM
wow guys, thanks for all the help so far. i am going to order the 5mm bore, Mod1 pinion with the 46t Kyosho spur. a few of each. we will start from there and hope things work out.
yes i know this is dirty. i had it at the track 2 days before i just brought it back and haven't cleaned it. although when i first got it, i took it all apart and cleaned everything. looked beautiful. but once i got to the track it was back dirty again within 5 seconds. obviously.
how do you keep everything so clean? do you completely tear everything down after each run? forgive my thoughts, but thats seems a bit much to have to clean every time you run.
Ofna Hyper 8
Medusa AfterBurner 2300
4s Zippy Lipo
MMM
Stock Chassis
"still in training to stop hitting ankles"
tha5150
tha5150's Avatar
01.05.2009, 02:29 PM
oh, of course. Pinion is out of stock at 16t
Ofna Hyper 8
4s Zippy Lipo
MMM
Stock Chassis
Sower
Sower's Avatar
01.05.2009, 02:32 PM
One thing I've done is create a custom mud guard for my XT8 at the front of the chassis. I also put velcro on the sides of the body and side mud guards to keep the body tight. Here's what I mean:
www.robsower.com
ssspconcepts
ssspconcepts's Avatar
01.05.2009, 02:36 PM
I don't do a deep cleaning after each run...just when it's needed. I do use compressed air after each run to blow the dust and debris off the chassis and out of my electronics.
During a deep cleaning, I use a lot of elbow grease, compressed air, gun cleaning brushes, Remington gun action degreaser, and then finish up by re-lubricating all parts that I use the degreaser on. A little WD40 doesn't hurt...but remember WD40 is technically not a lubricant...its application is for water displacement.
After I take one of my trucks out mud bogging, I remove the electronics and then use the high pressure sprayer to blast off the mud. After that, I do a teardown on all of the drivetrain components and put the WD40 to work. Then re-lube and re-assemble.
May not be perfect but it works for me.
tha5150
tha5150's Avatar
now THAT looks clean.
how do you get it so clean though? yea i would like to keep it clean but isn't there another way of cleaning besides a rag and simple green AFTER you take every last screw out?
but like on the insides of your tires, they look brand new..
would an air pump work at the gas station???
Ofna Hyper 8
4s Zippy Lipo
MMM
Stock Chassis
ssspconcepts
01.05.2009, 02:43 PM
Air compressors go for about $100 at Sears or Northern Tool and Freight....gas staion would probably work if they let you use the one that the mechanics use to power their pneumatic tools.
tha5150
tha5150's Avatar
01.05.2009, 02:50 PM
i was referring to the compressor you pay 75 cents for. lol
Ofna Hyper 8
4s Zippy Lipo
MMM
Stock Chassis
01.05.2009, 02:54 PM
Gas station compressors usually are fitted with the tire-inflation tip. You'd need to devise something that will push the little pin (to release the air), yet not interfere with focused airflow. Just go get a cheapie compressor!
tha5150
tha5150's Avatar
01.05.2009, 02:56 PM
100 bucks isn't in my budget.. well thats a lie.. truth is i just got married and she will say no. lmao
Ofna Hyper 8
4s Zippy Lipo
MMM
Stock Chassis
01.05.2009, 03:04 PM
Just get her some nice shoes and then she can't say no...
tha5150
tha5150's Avatar
01.05.2009, 03:09 PM
kinda like these??? hahaha
Ofna Hyper 8
4s Zippy Lipo
MMM
Stock Chassis
Sower
Sower's Avatar
01.05.2009, 04:30 PM
May sound funny, but an old toothbrush and a clean rag go a long way w/o needing to tear everything apart. The photo I posted was after a full tear down cleaning and some new wheels
Although a good 3M green brillow pad will make your wheels look almost new.
www.robsower.com
Sower
Sower's Avatar
01.05.2009, 04:31 PM
Actually those wheels weren't new in that photo - just cleaned with a scrub brush and brillow pad.
www.robsower.com
01.05.2009, 04:34 PM
Mmmm, yeah!
