himalaya
himalaya's Avatar
04.07.2009, 04:57 AM
Can't wait to see somebody take it apart to have a look inside. xx pole rotor? xx slots stator? Kavlar/carbon fiber wrapped rotor? winding lead/ silicone flexible wire/ solder tabs? .........
....What a Blue Sky....
Kajman
Kajman's Avatar
04.07.2009, 01:51 PM
Are any numbers known? Rm, Io@V, cont input power and so on?
Rcx 2009
js058515
Thank You Brushless Gods!
js058515's Avatar
Rcx 2009 - 04.10.2009, 07:58 PM
Hey Tekno,
Will you guys be at RCX in Pomona next weekend? I am itching to get my hands or eyes on a Lektron motor and the 8T 2.0 conversion. What's the pre-order date for the 8T 2.0 kit?
Losi 8B 1.0, Tekno V3, Direct-Drive, 13/48, RX8, T8 1400kv
Losi 8B 1.5, Tekno V3 w/clutch (3-shoe), 14/48, MMM, Neu 1512 2Y
Losi 8T 2.0, Tekno V3 w/clutch (3-shoe), 14/48, MMM, T8 1550kv
teknorc
04.10.2009, 08:35 PM
Originally Posted by js058515 View Post
Hey Tekno,
We won't be at RCX as an exhibitor, but we may stop in to check out the new stuff coming out. Losi 2.0 conversions are about two weeks away. I don't think we'll do a pre-order this time. When they are on the site, that means they are available. We should have enough to fill initial orders.
Tekno RC - Performance Parts
phatmonk
RC carbon junkie
phatmonk's Avatar
04.11.2009, 03:09 PM
These new motors look to be awesome but the square can on Mikes motormounts?Is this a issue.
SC8-E RCM MMM CC 1717
Slash 4x4 MMP CC SC 2400
riceman
RC-Monster Gold
riceman's Avatar
04.11.2009, 04:14 PM
The option to mount using the faceplate mounting holes is still there. Shouldn't be an issue.
drkdgglr
04.14.2009, 10:17 AM
...the lektron 2200kv has the exact same specs as the medusa 36-60-2200
For both motors:
Max Amps: 123A
Continuous: 102A
Io: 2.8
Rm: 0.004
Max Volts: 27V
Watts: 920W
The only difference is weight:
Medusa 36-60-2200: 290g
Lektron: 310g
Thomas
Thomas's Avatar
04.23.2009, 06:44 PM
With the new motors out, will you still restock the Tekno RC Edition Neu motors, e.g. 1512/2Y/F ? All 1512 are out of stock at the moment.
js058515
js058515's Avatar
04.23.2009, 10:53 PM
The Tekno guys will chime in on this one.....I actually had the same question as you. From what I was told over the phone the Lektrons will phase out the the Tekno Nue motors eventually. For some reason, Nue has been having a hard time with their quality control.
Unsullied_Spy
Unsullied_Spy's Avatar
04.24.2009, 12:33 AM
I didn't get the verbal spanking for mine, I used screws that were a bit too long and screwed up my coils. $105 isn't a bad price considering it was a total write-off and I should be able to get $200 for it.
js058515
js058515's Avatar
04.24.2009, 12:02 PM
The verbal spanking was worth it as they repaired/replaced my 1515 3d Square can for free. I think Nue's are great motors and don't mind paying for repairs as long as I can get some decent life out of it. I think the 1515 3d's were plagued with some disease as they were commonly being overheated. There have been some other size Tekno Nue's being complained about but they haven't been consistently breaking like the 1515 3d.
I am really interested in running a Tekin motor for the truggy and the buggy with the MMM to see how well those do. I was thinking about running the RX8 but was reading on rctech.net that for 6S the LVC can only be set to 18.0 and not higher. I didn't like that (though it should be a quick fix for Tekin) as I set mine between 18.6 - 19.0 volts for safety. If you run 4s or 5s, it should be a great speed control.
Freakycrawler
08.14.2009, 12:41 PM
Any chance i can safely run the 1800Kv or 1500Kv in a truggy on 5s ?
If not what alternative would you recommend?
Thx a bundle
teknorc
08.14.2009, 03:52 PM
Thx a bundle
These are not intended for truggy use. They are just a tad too small. Go with a 1515 or 1512 based motor instead (1515/2.5D or 1512/3D).
Freakycrawler
08.14.2009, 05:19 PM
Thanks you very mch, nice and quick reply'ed also
I will look into the ones you advise.
Thanks you guys
Topas
09.10.2009, 04:53 PM
Do I need a fan on the motor (Lektron 2200) in a Losi 8ight 1.0 Buggy ? After 10 minutes it is about 74 degrees C hot (gearing 45/15)
My hobby coin collecting: (in german)
Euromünzen
