Mentat
Brushless Mentat
Mentat's Avatar
06.21.2009, 09:45 PM
OH and this kit doesnt come with mounting screws for your motor either
FS: 8ight-t Race Roller TONS of UPGRADES
8ight 1.0 & 2.0 | 8ight-T 1.0 & 2.0 | E-Revo BL Edition | T-Maxx | Slash | Raze-ST | XXX-NT Drake | 3PKS | DX3S Telemetry
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
06.21.2009, 09:23 PM
Good to know, I was thinking about a 8ightE but now I may go the RC8 and Tekno chassis and save some $$$. Still confused ?????
Semi Pro
Semi Pro's Avatar
06.21.2009, 09:42 PM
Originally Posted by Mentat View Post
Warning do not buy the junk ARSE losi electric conversion kit. the plastic spur gear rubs against the rear center diff mount big time. JUNK JUNK JUNK not to mention that u can only use the plastic spur gear unless u want to cut up you losi race roller chassis and sand down the plastic part of the 45t spur gear, so glad my Tekno is coming. Others have reported this at other forums. Save your self $10 bucks and get the Tekno!
really sounds like you dont know what you are doing, i have the losi conversion kit and so do many other members of rc monster, none of us have had problems with it
Mentat
Brushless Mentat
Mentat's Avatar
06.21.2009, 10:21 PM
lick me and love it!
TexasSP
Something, anything, nothing
TexasSP's Avatar
06.21.2009, 11:16 PM
Linc, you need to stop being so rough at night with What's_nitro?.....
It puts him in such a foul mood the next day!
www.cubicle101.com
06.22.2009, 12:36 AM
Wow, I am guessing we have another female forum member? I swear I heard that line in a skinemax flick recently...
Not my fault he clenches the entire time.
himalaya
himalaya's Avatar
06.22.2009, 06:02 AM
I have the same problem. I replaced the steel 45T spur with a plastic to have a quiter enjoyment. I spent 2 hours trying to get the center diff spin freely, after countless assemble and disassemble the spur was still touching something. I finally figure it was the chassis! dremeled a tiny bit(0.1mm depth I guess) of chassis off right under the spur, the problem goes away. and like Mentat's picture shows, the spur was so close to the mount that I can't insert a piece of paper into the gap.
Now my center diff spins freely, but new problem comes up. This time it's the pinion's turn to touch the mount. I have to pull the pinion 1mm farther away from the motor to let it run free. WTF do they design it this way. I coundn't use the plastic spur's full teeth width, only 4/5 width is contacting the pinion.
The fact is, Losi designed the plastic spur so wide that it almost get conflict with the mount, but that extra width can NOT touch the pinion, it does not work together with the pinion, which is what it was designed so wide for. Is that logical ?
Yesterday I managed to run my 8ight 2.0 E conv, finally. It did run great but I just can't say it was a perfect design.
....What a Blue Sky....
DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
06.22.2009, 10:06 AM
after reading your post, i just went and looked at a couple of my plastic spurs.....they don't all seem to be exactly the same width. I wonder why this is?
Still, if you get the RCM mount, you'll have zero issues with rubbing on the chassis as it raises the center diff a few mm and i don't get any rubbing on the mount from the spur either. I run 45T with no problems at all. Not only that, it's an awsome mount that allows you to gear as high or low as you want. that's one thing that no other 8ight conversion seems to offer right now.
the wheel freespin i get is crazy...no binding at all. RCM mounts rule!
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
Edumakated
06.22.2009, 11:33 AM
The plastic spur definitely does not fit. It is too wide and the only way to get it to fit is to shim it away from the mount or sand it down.
However, if you set your mesh correctly, the metal 45 tooth losi spur works GREAT. It is nearly as quiet as the plastic. I have found that the metal to metal is loud if you set your mesh too tight, but just fine if you loosen it a bit.
You also have to dremel out the plastic hole covering a little bit as the spur may rub.
Other than that, the Losi kit is pretty nice. I like it in my 8t 2.0. Very simple to install and pretty solid.
Mentat
Brushless Mentat
Mentat's Avatar
06.22.2009, 04:59 PM
Where did u get the metal diff cup?
DwightSchrute
06.22.2009, 06:05 PM
here:
http://cgi.ebay.com/ws/eBayISAPI.dll...m=390015827060
i have to use them because i run my center diff almost locked....basically with putty in it.
when you have that much pressure in there, geared the way i do, i blew a dime sized hole in the stock one. these are incredibly strong. I got one for all 4 of my 8ights. a good investment imo.
Mentat
Brushless Mentat
Mentat's Avatar
06.22.2009, 06:18 PM
I am running 50,000 weight in my 8ight-t what do you think about that? that be ok? not sure what weight to run being brushless
here:
himalaya
himalaya's Avatar
06.23.2009, 01:51 AM
Yes, the RCM mount is what I am planning to invest.
Losi's mount is so thick that I can NEVER install my pinion like the way you did in you picture.
the Losi mount's center hole is so small that most of my mod 1 pinions can not be used because they have bigger bore(the untoothed section), like this one:
Also, the RCM mount allows the motor to move horizontally when adjusting mesh, making it much easier to make a motor rear end brace.
DwightSchrute from this pic it looks like you are using the Losi motor brace, how did you make it work together with RCM mount when adjusting mesh ? the mount moves the motor horizontally but the brace supposes the motor to move in a slope according to the losi mount ?
DwightSchrute
06.23.2009, 11:53 AM
i'm not sure i'm understanding your question. are you asking how the top brace that is over the spur gear still fits with the RCM mount?
if so, the rcm mount has a spacer that goes under the front mount so it levels out the front and rear mounts to be the same height so it really dosen't have any effect on how the motor is moved when meshing. it also raises the center diff some because the rcm mount is a bit taller than the losi mount. i hope that answered your question.
or are you referring to the black "L" shaped plastic that goes under the losi mount? if so, you don't need that piece anymore when you use the rcm mount because their taller and allow for more clearance for the gear. i have since taken them all out of my 8ights. I imagine if you used both you might manage a 48t spur, but i'm not sure.
himalaya
himalaya's Avatar
06.24.2009, 01:35 AM
Sorry for the confusion, English is my second language.
I was talking about the motor brace that lays underneath the motor can to support the motor body during hard landing. This component:
It is arc shaped, when you move your motor horizontally, this plastic brace will get in the way. The brace was designed for Losi's 39mm motor, thinner 36mm motors may have less problem here, but will have no support on the rear end of the motor.
