neweuser
neweuser's Avatar
04.24.2006, 05:52 PM
that's it...wierd!
neweuser
neweuser's Avatar
04.24.2006, 05:54 PM
couldn't i just mod this one? can i just cut the switch off and rewire it to the plugs?
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
04.24.2006, 07:17 PM
no doubt....it says....one plug is a charge jack...which looks to be the red square plug...the other red plug goes into the reciever..and the black one goes to the battery.........just hardwire the batt in place of the black plug and you should be good to go....open up the switch housing to make sure the red square plug is for charging....but I'm 99% sure it is.........did you find some 3mm screws for the strobe slipper yet?.....also by any chance do you have msn instant messanger or aim.....then I can walk you thru everything easier
neweuser
neweuser's Avatar
04.25.2006, 12:37 AM
yes, i do. i run everything thru msn....my emial would be better though, troynelson_672@msn.com ..thanks man. i got it to run tonite, thanks for he suggestion on the screws, stopped right after work...i posted on brusless too on 9920 programming help from i think finnster...reverse seems to want to go faster? hmmmm....not sure? My transmitter is the JR XS3, and my steering seems not to be very responsive, i think i need help programming my trans too....
