Sylvester
Sylvester's Avatar
01.07.2007, 04:44 PM
Originally Posted by Mike.L
your running two 2s2p 7.4 lipo cell packs? i have a feeling that those titans will burn out.
Why, they even last on 14 cells.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
Mike.L
Mike.L's Avatar
01.07.2007, 04:48 PM
jhautz, can't lipo be alot higher in voltage when charged then a nimh battery. i remeber a friend using 14 cell ib 4200's and burnt out 4-5 motors....thats was funny a dom?
  Send a message via MSN to Mike.L
GriffinRU
01.07.2007, 04:50 PM
If you add spacers in between motors and bracket it will help a lot with cooling problems. Better then extra heatsinks... Will work only with motors with built-in fan, like Titans, but not with like Trinity mild/wild/pro.
Artur
Mike.L
Mike.L's Avatar
01.07.2007, 04:51 PM
ya, i made some custom H sinks for mine alswell
Sylvester
Sylvester's Avatar
01.07.2007, 04:52 PM
Even though they are charged at a high voltage, the voltage noticably goes down when accelerating, so does the amperage.
I bet the titans would be able to surpass a test or two with 5s lipo or 16 cells.
Losi 8ight e
Mike.L
Mike.L's Avatar
01.07.2007, 04:54 PM
well i figured that.....sorry im a lipo noob guys
GriffinRU
01.07.2007, 05:02 PM
And 20 cells with proper gearing :)
18-cells was my favorite setup, so 5LiPo won't be the limit for Titan's, but would be for EVX. Super Duty XR would be sligtly better in that respect...or modified EVX
And bottom line not more then 180-200W from single 550 can
Artur
Serum
Serum's Avatar
01.07.2007, 05:13 PM
@ turbo4; do you like your dimensionengineering lipo-shield?
coolhandcountry
coolhandcountry's Avatar
01.07.2007, 07:26 PM
I found the lipo put more punch out so the motors would get warmer faster. I dropped the gearing a little and it would run cooler. It would also wheelie in second gear almost at well.
Peace!
Country
Help support the
Rc-Monster
Buy here
turbo4
turbo4's Avatar
01.07.2007, 09:27 PM
Yes, Im going to run (2) 2s2p 7.4 maxxamps 6000mah's. I have not got the packs yet(should get here this week) I have not even drove the truck yet, had it a week now just looking at it. Usually lipos will run 1.0v to 1.5v over there rating at a full charge. A lot depends on the quality of the charger it seems. Since I have not ran the truck I cant comment on the Lipo shield.
Joel
Where can I get a set of heat sinks for the stock titans?
Sylvester
Sylvester's Avatar
01.07.2007, 09:57 PM
You can check towehobbies, im sure they have got one.
Losi 8ight e
Mike.L
Mike.L's Avatar
01.07.2007, 10:13 PM
or you can make one, what i did was get a 1/4 inch alu pipe and cut it in half and then with a band saw made fins and superglued them to my titan motors...
i couldnt belive it that it worked so well.. and has cheap Money wise:)
revopqrs
uhhh-huh!
revopqrs's Avatar
01.10.2007, 07:43 PM
hmmm interesting... so you can run lipos on the evx? whats the little gadget that was mentioned earlier? does that allow the use of the lipos? anyone got a link?:030:
dont exceed 200watts per 550 can... good advise!:027:
so does 16 cells burn out the exv? i have some extra cells layin here..... running 14 now.
coolhandcountry
01.10.2007, 10:21 PM
What do you need a link to?
Peace!
Country
Help support the
Rc-Monster
Buy here
Procharged5.0
Procharged5.0's Avatar
01.10.2007, 10:36 PM
16 would be really pushing it in my opinion. I wouldn't.
The "thingy" is a LVC or Low Voltage Cut-off which prevents the Li-Po's from over discharging and damaging themselves.
