05.25.2007, 07:43 PM
If using ~12v, yeah, you could use a 12v fan. But I assumed he was using 5v fans. Still, 4s or 12 cells is more than 12v and may shorten the fan life. I would use a simple regulator to get it down to 12v in that case.
rchippie
rchippie's Avatar
05.25.2007, 08:01 PM
The 12v fans i bought only cost 3 bucks & move a lot of air. So if i got a month or two running a 12v fan on 4s lipo i would be happy & just buy another one.
REAL MEN RUN BRUSHLESS
bdebde
That's All Folks!
bdebde's Avatar
05.25.2007, 09:10 PM
They're so cheap, I buy several at a time, then ya got spares.
BlackedOutREVO
05.26.2007, 11:54 PM
well i raced with them, SUCKS!
even wired into the batt, i get HORRIBLE run time, and notecably worse punch and all =(
so now i need to ask more ????'s lol
05.27.2007, 12:43 AM
Fans shouldn't affect runtime that much. Unless the fans you are using are high speed ones, they should take no more than 100mA each. That would only affect runtime by 0.1Ah.
Alternatively, make your setup so it doesn't need fans. And/or cut strategic holes in the body for better airflow.
BlackedOutREVO
05.27.2007, 12:58 AM
it shure does, i can notece a difference
and yes i am, no, no holes... just idk
05.27.2007, 01:25 AM
Like I said, it shouldn't - at least not much. Typical fans should not pull enough current to affect runtime drastically like that. I would run without them on a cool day and see if it really is the fans that are causing your issues.
Judging by your other thread about your IBs, it sounds like your batteries may be the culprit since you are putting only 2800mAh back into a 4200mAh pack. Right there, your runtime is drastically reduced. If your fans were causing it, the charger would still be putting about 4.2Ah back into the packs.
BlackedOutREVO
05.27.2007, 01:27 AM
and idk, it seams like the fans are, but then again idk, could just be me...
yes i think so also, idk that i have ever put more then 3000 in, i dont remember tho, hmmmm well this is kinda dumb then.... idk what to say
