sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
12.05.2007, 04:55 PM
Also when I ran mine with MIP cvd's center or driveshafts, you can replace the setscrews with the stock emaxx driveshaft pin, that is used with the plastic shafts......it is a perfect and threads in nicely as well. But as newe said...letting the loctite cure and dry is the key and 24hrs seems to be the best bet
Bl E-REVO
Quark 125b
Castle Creations-Neu 2200kv motor
((2s2p)(4s)
7800mah 7.4v Lipo Pack
E-Revo 1/8 scale Hyper 7 CD
http://www.rc-monster.com/forum/show...1&goto=newpost
Duster_360
12.05.2007, 06:55 PM
The only other thing I know that messes up loctite - even a trace of oil or grease will make loctite either not setup at all or give you a weak bond that won't hold. I use motor spray and clean both parts before loctiting.
