Senior Strategist
01.23.2008, 01:09 AM
Originally Posted by gixxer
thanks for the update. can you let us know what the planned voltage is for the new hv system? I currently run 5s and plan on going to 6s but want to make sure your new esc will be able to handle that.
I love your motors for 10th scale but dont use your stuff in 8th scale basically because of the esc. Could never get it to run more then about 10minutes with out thermaling.
The new HV esc will be max 6s lipos. After reading these, and ther, forums, I told the engineers that if we couldn't design a new 6 lipo controller to just forget it. Our existing HV products are way overdue for replacement.
01.23.2008, 02:01 AM
Great, this is a big step forward for electric. We have at least two compainies bringing out 6s sytems with motors. This will go a long way to bringing larger scale electric to the masses!
03.06.2008, 10:30 PM
any updates on this? if its out soon enough maybe I can just skip the MMM all together.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
01.23.2008, 12:31 AM
how is the hv 6.5 working in the conv.
since it has a lower kv it should run cool and provide good speed in a buggy
im just wondering , because i tried a 4.5 tonight because of the mm update in a xt8, and it seems like if i gear down as far as i can go it would be an ok motor, but its probably going to run hot temps. on the motor, the 6.5 may be better for a truck due to the added weight, and lower kv on the 6.5
01.23.2008, 12:38 AM
? for NovakTwo........
what is the timing set at on the hv line of motors???
would like to continue testing this motor with my MM, once i gear it down to 11/48
01.23.2008, 12:59 AM
im sure that it will be a good system once it gets done, i really liked my hvmaxx system
i think the lower winds are a great idea, alot of people like the "systems" that are tested and matched to specific applications
01.23.2008, 01:24 AM
thanks and I look forward to seeing the final product.
BMW M Power!
01.23.2008, 02:30 AM
A sensored 6S system? I'm gonna like this...
01.23.2008, 02:51 AM
This sounds very promising;
6S, 5mm shaft, wider range of KV.
Now the next step is to upgrade the rotor to a slightly larger diameter to increase the torque, to enable the use the full potential of 6S; i think that because of the smaller magnets, you will hit the limits of a motor sooner. (copper and iron losses)
01.23.2008, 03:14 AM
everything sounds good. now as long as you guys can get it out on time you will have my $$$$.
Senior Strategist
01.23.2008, 08:15 PM
Bob posted a response on a forum at RC Tech that I will repost here.
Questions: .....Superior to what? What was used as a comparison? Was this the current HV setups or something else?
Very interested to see some more detailed shots. The 4 bolt design sounds like my RC Product Designs mount as it goes on with 4 bolts.
I like the size of the fan. How durable is it?
Last thing, and its probably a wording thing but I figure I ask to be sure, these conversions, are they compatible with the truggy version of the buggies listed?
Bob Novak: I have not seen your RC Product Designs mount. Let me explain how ours works. The heat sink replaces the center sleeve on the HV motor. There are two screws that clamp the heatsink to the laminations of the motor. This heatsink is common to all the conversion kits. There is a car specific plate that screws to the the bottom of the heatsink with four screws. This assembly is then screwed or bolted (depending on the Buggie) with four screws or bolts thru existing holes in the chassis.
Mounting this assembly to the chassis gives superior heat dissipation compared to mounting the motor at the front. Clamping the heatsink directly to the motor laminations also gives superior heat dissipation over motors that cannot be mounted this way. This heatsink will fit on any of our motors. The fan is also very rugged. These conversions will most likely fit on the Truggies also, but I just have not had time to test them. That will be my next project.
Thanks for the comments.
Bob Novak
nota newb
01.23.2008, 09:08 PM
any idea on a price range yet?
Senior Strategist
01.23.2008, 09:15 PM
List price is $139.00. Street price may be @ $90.00.
nota newb
01.24.2008, 01:15 PM
sorry i didnt make myself clear enough but i was talking about the brushless system itself and not the conversion kit
Senior Strategist
01.24.2008, 01:29 PM
We will do the preliminary pricing for the upcoming products once the designs are finalized and all of the new components are sourced. Final pricing is determined prior to the formal press releases with projected ship dates. At this point, price projections are pretty useless. The prices of metals continue to escalate.
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
