Go Back   RC-Monster Forums > Support Forums > Team Tekin
snellemin
2 KiloWatt RACER
snellemin's Avatar
08.12.2008, 02:11 PM
Originally Posted by chilledoutuk View Post
snellemin are you running a123 in 1p?
I suspect these tekin motors need a lot of current to get them going and in my opinion a123 cells are not quite good enough in 1p format to provide motors with full 540 size rotors with the current they need.
I ran in 1P mode. The 8s 4400kv feigao motor has more ummphh in 3s1p then the Tekin motor.
But the motor might be "designed" like that.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
Mister-T
08.12.2008, 01:43 PM
I did have use it on 2S2P A123, after a complete run pack come out warm. Unfortunatly I have nothing reliable to measure amp draw in a run :/
"We'll never have a ROAR legal motor. They're all copies of Novak's design. We're not willing to copy what we consider to be an inferior motor"
- Joe Ford - my new hero
Kajman
Kajman's Avatar
08.13.2008, 01:16 AM
I run 278 sometimes on 2s2p, it goes strong enough, 1p can deliver up to 70Ampers, so that is not that bad, try 2p if want to go safer.
Mister-T
08.13.2008, 11:36 AM
So Kajman,
Tekin 278 fits your need ? is that the speed you neeeded ?
Kajman
Kajman's Avatar
08.13.2008, 11:45 AM
Yeah, it is quite powerful, enough to use current limiters :) It is very quiet because of closed design, because of that little bit hotter, but anyway, very good engine untill now :) Speed is ok, I run it on my onroad and it is enough for everyday use :)
chilledoutuk
08.13.2008, 03:42 PM
a123 cells can deliver 70 amps yes but what people forget is that the voltage at this load drop significantly more so than normal lipo battery's.
You know what i would like to see would be an eagletree of one of these motors on a really powerful battery pack to see what current they really like to draw.
Mike.L
Mike.L's Avatar
09.01.2008, 07:28 PM
would a lower kv tekkin motor be good for a crt.5?
  Send a message via MSN to Mike.L
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
09.01.2008, 07:56 PM
I was going to use one when I was going to do a conversion for a CRT.5. The Traxxas VXL motor is a popular motor used in the CRT.5 and it is a 3500KV. Tekin make a Redline in a 3700KV which should be perfect
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
Mister-T
09.02.2008, 12:57 PM
Tekin motor are smaller, there are short can like castle motor
Kajman
Kajman's Avatar
09.02.2008, 12:27 PM
any idea anyone what timing is the best??
Mister-T
09.02.2008, 12:56 PM
I'm running custom 8 ° on my mamba max. It give sligthly more punch
Kajman
Kajman's Avatar
09.03.2008, 01:19 AM
OOooo, nice, I hve to reprogramm my esc, I run 30° on my Genius 95 and its a little bit hot :)
Mike.L
Mike.L's Avatar
09.02.2008, 03:54 PM
but a lower kv motor on the correct pinion to gear ratio then perhaps it shouldn't be a problem???
-note even though it is the same size as the mm cans..
Mister-T
09.02.2008, 04:34 PM
Might run a little hot. And might appear a little tame if your planning to bash in the street. But if it's for local race track it will be ok
snellemin
2 KiloWatt RACER
snellemin's Avatar
09.02.2008, 05:54 PM
I found the graph of the 448 Tekin motor on 4s A123.
60/14 gearing in a Rustler with 4" tires.
