Mike_D
Mike_D's Avatar
04.27.2008, 08:17 PM
Great looking Revo! BTW what tires and wheels are those?
bustitup
04.29.2008, 01:53 PM
Originally Posted by Sammus View Post
I'll be running a single motor, so I got the single motor plate mount for the 3905 tranny - looks like itll stick the motor in the middle. 6s2p A123 here we come :)
yes this sounds like the best bullet proof setup along with the innards of the 3905 diff's....and eventually I will be going this way soon as I get tired of playing with the twin v's and they finally release the combo MMM
bustitup
05.03.2008, 12:34 PM
I read a build the other day that says you can use a standard revo shaft for the rear and a 3905 rear for the front.
I've got my gear on its way :) I'll be running a single motor, so I got the single motor plate mount for the 3905 tranny - looks like itll stick the motor in the middle. 6s2p A123 here we come :)
UPDATE
yes I got my stock 3.3 revo shafts and one of them worked on the rear of my truck the other was too short (good spare lol) so I ordered a set of center shafts from a 3905 to use the longer one for my front
so your read was right Sammus
Sammus
Sammus's Avatar
04.27.2008, 08:24 PM
Look kinda like axial truggy rims (lol not that they look heaps different - I think I can see a logo there) with proline LPRs. I run the same thing in white. Corrent me if I'm wrong :)
bustitup
04.27.2008, 09:07 PM
yes they are Proline LPR series 1/2" offset wheels with crime fighters
big greg
05.03.2008, 12:46 PM
i used a stock 3.3 axle for my front shaft, worked great, couldnt have been any wider tho lol
bustitup
05.03.2008, 12:56 PM
hmmmm I thought of that..what did you have to do to the axle end to make it work?...any pics?
I have an extra 3.3 axle shaft I could try while waiting for my emaxx shaft
so when you take off that blue rubber boot..the axle slides together right there?
05.03.2008, 01:02 PM
Yep. The blue rubber boot kinda limits how long the shaft 'stretch'- if you need it to be longer just cut off the boot. If the shaft is too long, trim off the boot and the male half of the shaft, until it is short enough to fit.
bustitup
05.03.2008, 01:07 PM
yes but how do you address the actual metal axle end of the shaft so it hooks up to the output of the dif or tranny? (the yoke end)
big greg
05.03.2008, 01:04 PM
yup i just cut it were it was glued, you do have to shorten it about a 1/2 inch for the ends i used the yokes from the old revo shafts and diffs, the tranny side i just cut the pins off and i had to shave the edges back on the output shafts on the tranny
bustitup
05.03.2008, 01:10 PM
ahhh yes got it.......
thanks guys I may be on the road sooner than I thought.......let me see if I can go heat up some Velinion parts...LOL
I'll video the smoke
big greg
damn fast brit typer!
big greg
05.03.2008, 01:11 PM
i used the origanal yokes from the nitro shafts
big greg
05.03.2008, 01:12 PM
mmmm burn plastic gonna love it, dunno if you had an axle apart yet, but the slines only line up well in like one spot, make sure you note that
bustitup
05.03.2008, 01:18 PM
yes sir modded a few center shafts but never a axle shaft...yes I notice when sliding shafts together sometime there so tite but keep turning and find the nice slide.....thanks for the heads up
ya that plastic slag burns too
