OldGuy
Old Curmudgeon
11.29.2009, 10:49 PM
Thanks for all your help gentleman. The Baja is painted and the steering servo is fixed!
OldGuy
Old Curmudgeon
11.11.2009, 06:35 PM
Well, you are correct Spy, the gasser seems to be a GAS...pun intended. I really don't want to get into the whole moral issue of clones VS HPI because at this time it is a moot point. I opted for the clone so I could at least try out this hobby and see if it suits me. All help greatly appreciated.
Best regards
Unsullied_Spy
Unsullied_Spy's Avatar
11.11.2009, 11:38 PM
Best regards
If your clone Baja didn't come with a tuned pipe, GET ONE! GBE pipes are the best, but they're expensive. I have a used rear dom that I'll let go cheap, needs the pipe bracket bent back into shape but it's a good pipe.
When the tires go out, Hostile makes the best. I have the big, blocky Nightmares on mine and it hooks up great in the loose stuff and not too bad on dirt.
If it has a plastic diff case, get an aluminum one or your diff will rip itself apart really fast. I upgraded from the plastic one to the HPI Baja SS diff ($26 IIRC) and it has held up great so far.
Clutch shoes last a long time, but if you get a better CB carrier and a CB that is machined more true they last even longer. If you can afford a Turtle Racing HD Clutch system your clutch shoes should last a very long time and will be sealed from sand and dirt.
Out of the box you'll probably want a TGN Redneck pre-filter and Outterwears filters on the air filter and over the pull start cover but they're really good right out of the box.
I run 88 octane in mine but that's at 5,500 ft. elevation, not sure how that will work at lower elevations. I run Motul full synthetic 2 stroke oil at 25:1 and have got 3.5-4 gallons on this piston ring and it's still going strong.
I would start an account with HPIBajaForum, great wealth of knowledge over there. DO NOT post pictures of your Baja until it is customized a bit though, the people over there can spot a fake a mile away and they all take offense to them.
OldGuy
Old Curmudgeon
11.13.2009, 11:27 AM
HEY SPY Thanks for all the great information. I really need to upgrade the steering servo. I have bought a Futaba S 3306 in which I plan to put metal gears. Do you happen to know if this will this work in the Baja?
Best regards,
scarletboa
scarletboa's Avatar
11.14.2009, 12:29 AM
Best regards,
you will have to dremel the stock servo mount a little. my km baja stripped the stock servo after a small bump into a sidewalk. i got the Hitec ~$70 metal geared servo and LOOSENED THE SERVO SAVER and it runs like a champ. (except for the fact that my baja has collected dust for 6 months due to destroying my diff by doing wheelies using speed bumps, WOT, and the tuned pipe)
OldGuy
Old Curmudgeon
11.14.2009, 11:58 AM
When ya get a chance, please explain this procedure...........Thanks!!
scarletboa
scarletboa's Avatar
11.14.2009, 08:46 PM
in the steering assembly, you will see a little spring. there is a little thing you can turn to loosen or tighten the spring. most of them are way too tight from the factory.
Unsullied_Spy
11.15.2009, 04:55 PM
Best regards,
If that is a large scale servo, give it a shot. The Multiplex Digital Rhino is the most popular upgrade for the Baja from what I've seen. Good speed, torque, and great holding power.
OldGuy
Old Curmudgeon
11.15.2009, 09:39 PM
Thank you one and all for all the help. I installed the Futaba servo and have metal gears on order. The Buggy seems to be running just fine. Would never have been able to get her going without your help THANKS! Here's a video of the Buggy without body panels which I am still painting.
Unsullied_Spy
11.16.2009, 09:36 PM
Sweet! Large scalers RULE, once you go big you don't go back.
