scarletboa
scarletboa's Avatar
02.27.2011, 07:15 PM
Originally Posted by phatmonk View Post
What about running this motor in a Mugen MBX6 Eco on 3s.
if the buggy is light enough, i say go for it. my crt .5 is pushing around 7lbs and it overgeared and the motor still stays pretty cool.
phatmonk
RC carbon junkie
phatmonk's Avatar
02.27.2011, 08:01 PM
The Mugen MBX6Eco specs say it's 6 lbs.CC recommends 6.5 lbs maximum.
SC8-E RCM MMM CC 1717
Slash 4x4 MMP CC SC 2400
scarletboa
scarletboa's Avatar
02.27.2011, 08:13 PM
you should be fine then. it should run pretty good actually. i was expecting a lot out of the 1410 motor, considering it is based off the neu design and not only has it met my expectations, it has surprisingly exceeded them. this motor is about equivalent to a medusa 60mm motor as far as power handling. i would be shocked if you could even get that motor over 150F in that buggy, and that's without the blower.
asheck
03.03.2011, 10:25 AM
Now don't start getting delusions of grandeur . :) A Medusa 60, it ain't. They were a bigger rotor motor. I ran one in my E-revo for about a year, the 1410 isn't gonna handle that.
But it is a great motor, and my point here is that I data logged mine, in a Pede 4x4, geared 11/54, with Trencher tires on 3s. Ran 54 mph, and pulled 116.8 amps. Had lot's of bursts in the 100 range. No temp issues, still.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
03.03.2011, 11:41 AM
I will agree that I don't think it's quite on par with a 36-60 Medusa but I think it does surpass a 36-50. There's no way I would try pushing a e-revo/maxx with just one of these. The motor is very impressive though. I think instead of the blower though they should include a fan that can snap onto the esc, the blower is a waste with this motor
scarletboa
scarletboa's Avatar
03.03.2011, 11:42 PM
hmmm...alright, well, i might have been exaggerating just a little. the 60mm medusa i had was not in exactly the best shape and it has comparable temps in the same setup geared for the same speed at a similar max rpm. the bearings were getting pretty rough too in the medusa.
i do think these would do alright in a maxx or revo geared for ~30mph. once i get my revo fixed, i will try it out and might finally have a reason to use the blower.
hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
03.16.2011, 06:39 PM
I run mine in my losi scte...geared 16/40....2s 65c 5600mah proteks...back to back runs without any rest (except to swap out lipos) will get this motor up too 200F...(on a 1/10th scale track pretty decent size)..it's a good thing the windings and magnets can take temps waaaaay above 200F... ;)
Losi SCTE
MMP/1410 3800kv
2s 65C 5600mah proteks
Dx3s
Thomas Porfert
Thomas Porfert's Avatar
03.16.2011, 10:56 PM
Just be careful with those numbers.. That magnet can handle a bit more than 200° F, but I wouldn't say way more though; and remember the temp on the outside of the can is not the temp of the magnets. I would let that little guy get a bit of rest in-between batteries; it's a good motor, but it does have its limits.
I am curious about that setup in the new Losi SCTe. We haven't received one to test with yet, and it is a bit heavier than the other 4x4 short course trucks. With that gearing on a single battery run, what kind of temps are you seeing on the motor? And are you using the Sidewinder SCT ESC or a Max Pro? Thanks!
Thomas Porfert
Tech Support
On the fence...
Big House
Big House's Avatar
On the fence... - 03.16.2011, 11:21 PM
I am shooting for 100+ with a converted Super Nitro RS4. Currently I am running a MM on 4s with a Medusa 36/60. It is geared at 44/20. I love the Medusa but I am wondering is it time to retire it for a smaller higher Kv motor for bullet runs. The car with the battery and body is 4.69lbs. My only issue is the 1410 is smaller in diameter to the Medusa. It also seems like this should be the perfect replacement for the MM7700 in my TA-04R as it weighs a mere 3.14 lbs. I am shooting for 100+ with it also. Let me know what you all think.
CF Ofna DM-1 Pro CC1717
CF Sportswerks Mayhem ST
CF Losi LST2
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
03.17.2011, 12:00 AM
The 1410 isn't smaller in diameter than the Medusa, at least not by a noticable amount
Big House
Big House's Avatar
03.17.2011, 10:40 PM
I was looking at the Castle website and it stated the 1410 is longer than the 36mm motors but the diameter is 25mm where as the Medusa is 36mm. But the thing that caught my attention was the fact they(Castle) said it was an improvement over the already excellent 36mm motors.
CF Losi LST2
scarletboa
scarletboa's Avatar
03.17.2011, 10:45 PM
You read the diagram wrong. The bolt pattern is 25mm, not the can diameter. The diameter is 35.8mm.
Big House
Big House's Avatar
03.17.2011, 10:55 PM
Thanks...the picture is kinda misleading.
CF Losi LST2
hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
03.17.2011, 12:05 AM
@Thomas...
After one run (about 14min) the motor goes from a resting 68f to 160f without a shroud...with the shroud, the motor is cool (135f) in the center but the temp from the endbell still reads around 160.... I run this in an indoor clay track (http://www.capitalrc.com/) ...I'm not sure how much this truck weighs since I don't have a scale but it def is heavier than the slash 4x4...
Complete setup is as follows:
16/40 gearing
5/7/3 diffs
Aka wish bones mounted on stock scte wheels
MMP (no timing or punch control...throttle curve is pulled up 2-3 squares from the middle to the upper left corner (forgot what this shape was called lol)
2s 65C 5600mah protek lipos
Dx3s sr3100t
I'm no hack so i don't spend a lot of time on my lid or hitting the pipes but I do run pretty aggressively...Btw, Thomas, I though I read somewhere that the windings could withstand 180c and the magnets 250c...???
Losi SCTE
MMP/1410 3800kv
Dx3s
fastbaja5b
fastbaja5b's Avatar
03.17.2011, 01:23 AM
Would this motor handle say an RC8 (got enough spares to make one) dressed up as a Corr truck on 2s (SC8 Bumpers, Shock Towers and Body Posts, SC10 Body) and geared for 30mph?
Not sure what sort of weight that'd be (RC8 is in bits) but I wouldn't imagine it being much more than a Hyper 10SC?
Say Less, Do More.
