Got both of mine working - I tried the emailed package that doesn't work on my machine on my wifes and it worked.
Ran on mine to the error point and rather than cancelling I terminated the tasks to leave the registry intact. I then copied over the binaries into the program file dir and created the desktop icon. Now all good!
Are either of these computers Dells? You copied the binaries from the computer that the installation workedon, right?
Jerry - Both home built - Send me your email and I'll send you a zip of the CC directory files.
Then run the normal install - at the point of error do not do anything - start "taskmgr" (start->run) and go to processes - Select applications and end task the install package.
Then unzip my file in the program_files directory - double click on the castlelink.exe to run.
Fingers crossed it worked - then just create a desktop shortcut!
It worked! Then I got an email from Joe at Castle that had a zip file in it that also worked. He said that they are looking into it so I'm sure it should be fixed soon. Now all I need is to get my Monster back.
Are they going to put it up on their site or do we have to email them?
I'm sure they are going to put it on the site. Joe just sent me another zip to test that worked, so it appears that they have found and repaired the problem. If you need before they do put it on the site pm your email to me and I'll send you the zip file.
I am know all confused on this thread. The zip is to get the Castle Link to work on certain machines and the new castle link includes firmware for the new MMM esc to be able to set custom LVC. This will not fix the bec from actually failing though??? Please someone fill me in on this. I think i got it right but......
I installed 3.05 and at first I had issues and the system would not install, I than tried again but the 2nd time downloaded as system adminastrator and was succesful with Vista 32 bit
