rchippie
rchippie's Avatar
12.18.2005, 10:49 PM
I like this version better than your last version. No offense intended. Your batterys are pretty low do they hit the ground ?
REAL MEN RUN BRUSHLESS
GriffinRU
12.18.2005, 11:07 PM
Good input always welcome!
First one has its benefits as well.
I build battery housing to be strong, to protect future LiPo cells. So, yes it does come in contact with ground but nothing to worry. That how it looks after 10+ runs
I built it from 3 parts, if you do the same as one, then you can level battery cover with f/r skidplates. But if you worry about ground clearance then my first setup would be better.
Artur
P.S. Try to put 6 cells between front and rear skid plates. You will get better picture of what I am talking.
rchippie
rchippie's Avatar
12.18.2005, 11:44 PM
That battery tray looks pretty strong. Plus it also stiffens the chassis. Your CG must be alot better with this setup than your previous one :p .
crazyjr
crazyjr's Avatar
12.22.2005, 11:29 AM
once again very nice work. Much better design
ttrmike
got truck
ttrmike's Avatar
01.09.2006, 08:32 PM
Anyboy know anything about the controler this guy used, cause it look really small. And I checked out the website an dnot sure if you can buy from it.
GriffinRU
01.09.2006, 09:23 PM
Schulze 18.97 KWF
Artur
ttrmike
got truck
ttrmike's Avatar
01.09.2006, 09:34 PM
No the guy Kraeuterbutter was posting for, the SBL mega powerboard.
