RC-Monster Spudgunner
12.12.2008, 06:10 PM
Is this the end? Any updates?
Soldermaster Extraordinaire
12.12.2008, 08:12 PM
No. I have been working on other projects lately. AKA the crawler.  I've had Christmas shopping to do, too, so I'm kinda short on cash.
01.08.2009, 02:21 AM
I talked to him a while ago. The pinion cannot be made to fit a 6mm shaft; the tooth count is too low. He doesn't have the capability to make a compound bore. I have been working on other projects lately, the Berg 2.2 being one of them. I'll need to buy another suitable motor with a 5mm shaft, then get the pinion for it. I'm still "working" on it but I don't have any further updates.
01.08.2009, 11:40 AM
just shave the shaft of the kb. grip it tight with some sandpaper, run it, and check often for fit. people have also used a dremel cut off wheel, ran the motor and moved the wheel up and down the shaft until a pinion fit. people are always afraid to grind on shafts, which perplexes me. they'll launch the motor off a ramp at 60mph, but won't grind that precious shaft! it's just a hunk of metal, it won't even get mad at you!
01.08.2009, 11:12 PM
I don't want to grind down the shaft only because I'm afraid I'll f**k it up.  I will probably opt for a Feigao L can, just because it's an inexpensive choice. If it works out I might upgrade...
01.15.2009, 12:56 AM
Just grind the can. Its easy. Push the pinion through a plastic bag, as to keep metal shavings away from the magnets. Turn it on, and grind it down. It really is just a hunk of metal and will be totally fine.
If you are like me and watch Horsepower TV on Saturdays and Sundays, you see people grinding down metal all the time. It is just the way things work when you are trying to make a sweet custom project.
01.29.2009, 12:06 PM
I ordered a pinion from Mike yesterday- (5mm/12T/32p). I hope it isn't too much trouble to get it centered in the gearbox with the motor mount I made. It has a bit of play so I think I'll be fine. If I can get it to mesh properly I'll be "beta testing" with a 600XL and 4s LiPo.
01.30.2009, 12:26 AM
Don't have the pinion yet!!!!!!!!!!!!!!!
01.30.2009, 12:33 AM
Hurry up!
01.30.2009, 01:37 AM
Rawrrrrrrrrrrr!!!!!!
01.30.2009, 01:46 AM
Hmm, is this a pic of Harold before the surgery?
01.31.2009, 02:59 AM
02.01.2009, 02:31 AM
Check it out!!!!
This video is crap. I forgot to set-up the resolution on my camera, and I put everything away before I realized it. At least the sound is decent. Sorrryyyyyyy...
02.01.2009, 03:17 AM
I'll be charging up the battery after work today. My plan is to buy a MM and get it to fit in the case, which will require it to come out of it's case...
02.02.2009, 01:43 PM
i didn't okay that pic for public use, i'll let this one slide..........
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
