Hey Guys,
Just wanted to post up quick about our new power supplies. Thanks you for your interest. I will try to keep this as short as possible. If you have any additional questions please feel free to ask and I will try to respond in a timely fashion.
Here are our two new power supplies:
http://www.maxamps.com/Power-Supply-12V.htm
Specs
* 100v-240v AC Input Voltage
* 12.15v DC Output Voltage
* 47A Continuous Output Current
* 575W Output
* 11" x 2.25" x 3.125" dimensions
* 3.25 lbs
* Short circuit and over-voltage protection
* Heavy duty metal cabinet
http://www.maxamps.com/Power-Supply-24V.htm
Specs
* 24.3v DC Output Voltage
* 1150W Output
* 11" x 4.5" x 3.125" dimensions
* 6.5 lbs
Both power supplies will charge at 47 amps all day long. A number of us have tested these and I know the guys at Big Squid RC have been using the power supplies with great results. Were talking about running two chargers each at 20 amps.
Regarding some of your comments:
One of the first things I wanted to do at maxamps.com was come out with an affordable power supply. I come from the computer industry and before that the electronics industry before I ever worked in RC. Day 1 at maxamps.com I started looking for power supply distributors and an affordable way for the general guy to be able to power his chargers and other devices at a rock solid price. I myself have built computer based power supplies and used them a number of times in the past for a number of uses.
We are not hiding that these are made from computer power supplies. We went that route because they are more affordable for average Joe. Right now it costs around $125- $160 for a good 20 amp power supply. Unfortunately this is only good for one high-end charger. There is a need now for more power with the latest Hyperion and FMA charges, among others that will follow suit shortly.
These power supplies are an incredible value for a quality product. MaxAmps.com are getting a really good quality power supply then we are modifying them ourselves at our shop. These supplies are wired correctly by electronic experts and are voltage checked for proper polarity and correct grounds.
We as a company cannot recommend to anyone doing these mods yourself. Modifying power supplies is dangerous and is something the average Joe should not be doing. If you guys mod them and they work that is fantastic. You are not the average Joe.
These power supplies are an affordable way to get the standard RC charging at a good rate with peace of mind that he just plugs in it and goes. No modifying. No worrying about shocking yourself. No worrying about ungrounded circuits.
A couple of you are posting some comments regarding legal issues and copying and things of that nature. There are a million computer supply mods out there and I have read a number of them. I believe this one actually exists on a number of sites as it's a popular server power supply. We did not steal anyone's idea and were not ripping off anyone's mod. We have the spec sheet from the manufacturer and we modify these power supplies to be both safe and easy to use.
Thanks and if you have any questions for me please let me know. Just understand that I am busy and trying to get done a lot this week. Wow that was a much longer post then I anticipated. Cheers
Brandon
