Hickoryhead
RC Wanna BE
Hickoryhead's Avatar
11.13.2007, 02:20 AM
Originally Posted by drkros3 View Post
yah it was that i needed to flip the diff's and i tired to switch the wires but it did not work. but that day i locked it into second lol. so i did a lot of work that was not needed lol.
but its all cool i was showing it off at work today and i broke a lot of stuff. like the 1 spur gear, 3 wheel hex's, 1 front diff, 1 push rod, and 1 rpm arm lol.
i did not konw that a poll could do so much damage haha. but its all fixed and its good. i got to try not to brake it any more cause i dont get paid for 2 more weeks and today was an expensive day.
oh yah and i broke the tekno wing mount cause i was doing backflips off of the curb. hahaha
I know how you feel. Check this out. It happened 3 weeks ago.I am still down. $120 later.
http://www.rc-monster.com/forum/showthread.php?t=8313
NECESSITY IS THE MOTHER OF INVENTION
Emaxx Tranny slipper modification (Strobe like)
http://www.rc-monster.com/forum/showthread.php?t=9341
drkros3
11.13.2007, 02:28 AM
damn that sucks lol.
well this is my arm that was said to never brake lol
and this is the hex that is not a circle
oh and for the wing mount i broke the screw off in side of the wing mount haha. i dont have a pic cause i left it at work
Hickoryhead
RC Wanna BE
11.13.2007, 02:33 AM
Ouch. But its the nature of RC.
drkros3
11.13.2007, 02:40 AM
yup yup.
also just wondering would betting the whole tranny gears in metal by robinson racing be better since i feel like the gears in the trany are going to just strip
http://www.impaktrc.com/product_info...oducts_id=1060
also if i get that would i still be able to lock it into second?
gtxracer
HOOH HUAH HOOH! Aww Baby!
gtxracer's Avatar
11.13.2007, 02:52 AM
Well, are the RPM arms at least a little bit stronger than the stockers? I just tore the cantilever link out of the "driver's side" front arm. Hopefully stockers will hold up next time.
:D
Hickoryhead
RC Wanna BE
11.13.2007, 02:56 AM
yup yup.
Wow! Thats like asking which Neu motor you should buy. Its a matter of opinion. Some people like plastic and others like metal. I personaly like plastic. usually only 1 gear breaks or strips. Cheap fix. But if you have metal gears the pressure that would break a plastic gear has to be transferred else where. If you buy metal gears the pressure that would break them will be transferred to break something else. What would break, who knows. You need some cheap plastic parts to take the beatings sometimes.
Hickoryhead
RC Wanna BE
11.13.2007, 02:59 AM
I only use RPM for my plastic arms. I use aluminum for lower arms though. Never broke any arms yet.
drkros3
11.13.2007, 04:01 AM
the rpm ones are stronger then stock. cause i know if i had stock ones on it would of tore them off when i hit the poll
also on the gears i was just wondering if any one had used them and was able to lock the second still. i think i might just still with the stock ones just because its like 100 for the gears lol.
drkros3
11.15.2007, 12:47 AM
hey i just had a question about the braking.
would it be better if i where to use the motor braking or should i get the mechanical braking?
also whats the dis advantage of doing this
squeeforever
squeeforever's Avatar
11.15.2007, 12:59 AM
Mechanical would be my choice.
drkros3
11.15.2007, 01:14 AM
would i still be able to do with even though i locked it into second.
MetalMan
MetalMan's Avatar
11.15.2007, 01:18 AM
Yep, you'll just want to disable the brake on the ESC (or set it to a very low strength).
drkros3
11.15.2007, 01:23 AM
what about making the servo work. i heard that you use a y harnes?
MetalMan
MetalMan's Avatar
11.15.2007, 02:27 AM
A y-harness connecting the ESC and brake servo to the same channel will do the trick.
drkros3
11.15.2007, 02:42 AM
oh ok i get it. maybe i well order that servo tray by tekno and then try this.
i kinda dont like the sound the motor makes when it brakes lol.
