azjc
08.13.2008, 11:15 AM
Originally Posted by ReV:-O View Post
o right. 100A continuous isnt actually that much if the battery can do 150A continuous, its kinda limiting the motor. maybe i should go for one of the MGM's, they look pretty capable although they dont have a fan so i wonder how they keep cool...
they keep cool due to good quality hardware and design....if you have those 2 things there is no need for a fan, and stay away from a Quark
Semi Pro
Semi Pro's Avatar
08.15.2008, 08:55 AM
Originally Posted by bl-is-future View Post
the v2 is all sorted out now so i would get the MMM.
i have seen afew posts about v2's with the same problems as v1's
side note, will running my 2.5df on 5 cell cause extra heat?
08.16.2008, 10:06 AM
So far the V2 mmms have been okay- only 4 known failures reported.
Your 1515 2.5d is only a 1650kv motor, so it will do just fine on 5 or 6s lipo- just afjust gearing accordingly.
ReV:-O
RC-Monster Carbon Fibre
08.16.2008, 10:55 AM
but the 1521 will be better because it has a slightly higher kv rating and its more powerful so i can gear it higher and get better top speed without sacrificing any low end.
with a more powerful/bigger motor, will that use up more battery even though it says it has the same amps?
azjc
08.16.2008, 12:14 PM
a 1515 would be plenty of power for you and good luck with your drivetrain you will need upgrades....I get 50 mph with my Revo and that is about as fast as you want to go with a MT
08.16.2008, 12:53 PM
Heh, 40mph is scary enough- you need alot of space and smooth ground to use all that speed... *said the voice of (limited) experience*
ReV:-O
08.16.2008, 04:08 PM
nah, when you have an entire park all to yourself... acers of land... you just wanna go as fast as you possibly can. 50mph is too slow lol - 60 minimum!
azjc
08.16.2008, 09:41 PM
if you are interested in over the top vehicles check out these 2 threads
http://www.rc-monster.com/forum/show...&highlight=xtm
