Z-Pinch racer
04.26.2007, 11:51 PM
Aah, yah I have a V2, I just bought it in January.
I did notice I have less punch with the Eagletree connected though, do you find the same thing?
04.27.2007, 04:01 PM
I can't say that I have noticed less punch with the MicroPower, but I'm sure that's how it is. It uses a shunt to drop voltage across, and that shunt has resistance, even if it is small. I don't know if you have felt the MicroPower after a run, but mine gets warm.
Z-Pinch racer
04.27.2007, 05:31 PM
i don't know for sure, I was playing around with the settings too, that might have been it, I might have changed the torque dynamics selection to soft. Mine does get warm too after a run. Have you checked out the graph I have of the Eagletree, does that look typical to you for your A123's?
04.28.2007, 01:19 AM
It's kind of hard to tell what the specific numbers are with so many minutes worth of data. Would you be able to get a zoomed-in version of maybe 30sec.?
Z-Pinch racer
04.28.2007, 01:34 AM
Can you zoom in the graph? That would be really useful, as the graph I have now is kinda general, you know.
I'll make another good run tomorrow, and see how it goes.
BTW, how do you charge your A123's? Do you use a Lipodapter or something, I know there is one meant for them.
04.28.2007, 11:43 AM
To zoom in on the graph, you drag from the upper-left corner of where you want to have it zoom in on, and finish at the lower-right corner. To unzoom, you do the exact opposite.
I charge my A123 packs on a "hacked" Astroflight 109. It charges to about 3.65v/cell.
I used to charge my 5s2p packs using a Duratrax ICE in NiMh mode with a LipoDapter.
Z-Pinch racer
04.28.2007, 12:39 PM
So, do you do a complete CC-CV charge? For a 5s2p, you would cut off charge at 100mA.
I'm gonna go try that zooming now, thanks.
04.29.2007, 01:15 AM
The AF109 charger isn't a CC/CV charger, but it does CC, and then goes into a pulse mode to keep the voltage at the maximum point. The Lipodapter doesn't allow for CV, and only CC.
Z-Pinch racer
04.29.2007, 02:45 AM
Didn't think so. That explains why I have 20 mins of runtime and you have 15 min you say roughly?
Also, I don't know if I asked you before, but what gearing are you using? Total reduction.
What temps does your 7XL run at? I managed to get it to 70Celcius (158F) today.
I am just getting my Eagletree calibrated properly now. So I will post a good eagletree run tomorrow sometime, of 30 sec like you requested. I'll zoom in on a spot with a good range of current levels and stuff.
04.29.2007, 03:53 PM
The AF109 will still do a 100% charge, it's just that instead of doing a CV phase, it does a pulse phase that keeps the pulses going until the battery doesn't need any more pulses to stay at the max. voltage.
My Revo has a home-made "slipperential" that uses the same gearing as Mike's Slipperential, and I have 20/40 pinion/spur on stock diffs. Total reduction is 12.52:1, and I think I need to use a 46t spur instead, so the FDR will be 14.40:1.
The 7XL runs under 160 deg. F, usually about 140 deg.
