GriffinRU
06.25.2007, 06:55 PM
Originally Posted by suicideneil
The brakes certainly work well, and no sign what so ever of cogging- even though it isnt hooked up to a drive train obviously but still. Whats the next test- 12 cells I guess.
Q. Did you ever findout how manu cells a HvMaxx will run without going pop? 18 cells would certainly be a nice bit of speed, provided the motor bearing could hold up.....
Couple tests here and there and then I will mail it to Mike for full-scale testing...
My HV-Maxx controller start losing control with 16 cells. I tried to modify it, but end up blowing internal caps.
P.S. Thank you everyone for comments, we will see how it works under the load.
Aragon
06.24.2007, 06:10 PM
Nice work!
Now why can't Castle do with the MMM in over a year what Artur has done single handedly in... a month??
06.24.2007, 06:13 PM
Because they dont have Arthur working for them! The man is a genious....
MetalMan
MetalMan's Avatar
06.24.2007, 11:39 PM
Wow, and it still looks good! I think my Revo could use one of these...
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
06.25.2007, 12:45 AM
Wow, looks great Artur! It seems to run very smooth as well. Is that you braking? I hope? :005: Should run nice and cool with dual power boards and those large caps on there, very nice work man. Congrats!
Wait till you see the Quark controller I'm rigging up. ;)
06.25.2007, 07:06 PM
Bummer. Im sure Mike will give the MM a thorough work out though. If it does go well, you'll have to think of a name for it...
GriffinRU
08.31.2007, 06:43 PM
There are updates to this thread here
Cowboy
10.01.2007, 02:45 PM
I'm modding my mamba max as per your instructions. I'm not sure which TVS to order. Could you post a digi-key part number for the TVS you used in the stage 1 mod.
GriffinRU
10.06.2007, 01:03 AM
Sorry for late response, currently I am far from internet (vacation until Oct.10) but here is link for parts.
Serum
Serum's Avatar
10.06.2007, 02:18 AM
Have a good one Artur!
GriffinRU
10.06.2007, 02:50 AM
Thank You Rene,
Grand Canyon fantastic place, last week was in Vegas...
By the way mod3a and mod3b is coming soon.
Mod3a 5S 300A (~500A at 25C)
Mod3b 15S 100A (~250A at 25C)
For 15S version to set voltage cut off I'm planning to use trimpot or jumpers, which one you will prefer? I am trying to use the same MM software but to make a walk around :)
Serum
Serum's Avatar
10.06.2007, 02:53 AM
The trimpot would use smaller footprint, so i would go for a trimpot.
Have fun in the GC! we had a good time in the US as well. (NY, VT)
10.07.2007, 06:08 PM
Smaller footprint yes, but trimpots tend to get dirty and then you have to consider wear over time if tuned a lot. Jumpers are bigger, but better IMO.
GriffinRU
10.12.2007, 12:11 PM
Thank you Brian and Rene for input,
I think, I found better way to monitor LiPo cutoff without additional trimpots or switches, only programming with Castle Creation software.
There will be some odd wiring, but that shouldn't be a problem with more then 4S LiPo. Actually, that's probably will be the only correct way to use LiPo cutoff.
And, Yes I am back from vacation.
GriffinRU
10.19.2007, 03:42 PM
Mod3 prototype board for MambaMax.
Mods for Quark:
Copper heatsink, assembled (temporary with alum. side panels), bottom side with taped holes for fixing inside stock housing, top view inside stock housing, same view with brains.
Details later...
