05.28.2007, 01:19 PM
ok thanks. so far everything seems ok but one never knows what quark will do :)
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
05.28.2007, 01:21 PM
I wouldn't go crazy; the inductance might be a point of concern at a certain point?
Z-Pinch racer
05.28.2007, 01:27 PM
Wallot: I checked out your webpage... Is that a Silencer heatsink you have your Quark sitting on top of?! :018:
Serum: I'm not really sure on that. You think that would be a problem?
05.28.2007, 03:01 PM
I took out my Hyper 8 with MM, Neu 1512 2.5D, Maxamps 4s 5000HV, and 4-cap bank. Unfortunately the cogging was still there as before, but it didn't seem as harsh as before when it did occur (which was roughly 50% of dead-stop pulls of the trigger). However, I DID notice a difference in temps - the motor seemed to be maybe 10deg. cooler, the battery was a bit cooler, and the MM didn't even feel warm (although this time it did have a small 25mm fan). I can play around with the ESC settings to see if I can reduce the startup cogging.
Z-Pinch racer
05.28.2007, 04:27 PM
That's interesting that your motor would run cooler, maybe it is switching from phase to phase more efficiently? Just a guess.
So i guess it does not help the MM with cogging the Neu motors, must simply be the software, and nothing but.
At this point though, it looks like it is for surely helping to reduce esc running temp.
Z-Pinch racer
05.29.2007, 07:21 PM
Well, I got my Quark back today, surprisingly fast. :003:
It is raining today, so no running. I took it apart and tried to look at the capacitor markings.... the brand looks like it's 'SANNHA' 'WB' series. I have never heard of that brand, and I can not find a SINGLE thing searching for it.
I think S&T are having trouble with 'Quality Control', my new Quark has a few near cold solders. And the caps have burn marks all around from soldering them on. The middle motor wire does not have solder on the top half of the pcb, not good.
So I was pretty dang close as far as guessing the measurements for my custom quark case. Only .5 - 1mm off hear and there.
I will fix all measurements and post a screenie of the quark case.
05.29.2007, 09:23 PM
Perhaps there has been an increase in popularity for the Quark controllers and they are having trouble meeting demand?
05.29.2007, 08:45 PM
Those look like very good caps (very low esr rating), though I wander what the rated voltage is on them- if its 25v maybe thats why they dont like 6s (until the power drops off from full charge a little)?
Z-Pinch racer
05.29.2007, 09:32 PM
Thanks Andy, they do look pretty good.
They are 35V, 330uF, and 0.0038 Ohm ESR Impedance.
No one knows what the problem is with the Quark not liking 6s LiPo. It could be alot of things, but maybe it's not enough capacity on the caps, just maybe. Has anyone actually ran 6s Lipo with 100% success?
silentbob343, maybe, it's a shot in the foot though really, for them, if something goes wrong with them. I sure hope this one works as it's supposed to. I wonder how much these would cost if made in the US, or Canada? :005:
05.29.2007, 09:09 PM
unfortunately !
Is 330uf/35V stock. can't support 6S is not Cap's problem!
since Quark esc is 5S max, i think they mistake data.
i am very sure.
so in korea local hobby shop they quark alway is
Cells : Ni_Cd 5~16 cell
Lithium 2~5 cell
take look here http://www.psyhobby.com/shop/shopdet...ch=&sort=order
05.29.2007, 09:43 PM
Z-Pinch racer
05.29.2007, 09:49 PM
How come that says 5s lipo? Is that in Japan, or Korea?
Also, why does it say 2-5% POWER UP turbo, what is that?
05.29.2007, 10:12 PM
is in korea.
05.30.2007, 10:22 AM
ZPB, Frank didn't mention any specifics.
I finally got an email from S&T yesterday. They said to send it in and they might warranty it. I know that I did the mod to it and I was working on it, but on the other hand, the Quark wasn't put together very well either. I'm hoping that they will warranty it.
I also heard from MGM and they said that they got my Compro just yesterday. I sent it via Global Priority, but it took over three weeks to get there. This sucks. If my Neu doesn't run well with the MM, then it's just going to have to wait.
If S&T doesn't warranty the Quark, I don't think I'll be getting another. I think that S&T has much of their resources devoted to the new controller that they have coming out and the Monster Pro is suffering because of it. I mean, what are the odds that I'd get two Monster Pros in a row that would give me trouble.
