glassdoctor
TEAM FUSION
glassdoctor's Avatar
06.18.2007, 02:34 PM
Losi has the reputation for being a little tougher than AE. Some guys who switched from a XXX to a B4 recently were complaining about breaking stuff.
With either Losi or AE you can get help form local racers and online. Especially with the trucks.... there isn't really much difference at all in performance.
As for the track... we took out that whole tricky section after the triple jump. Now you can hit the triple and keep going straight pretty much. And the table top now keeps going into another table jump.
I think going with a nice (normal :) ) stock truck for racing is a good idea. I would recomend running the 3300 also. If you don't run standard nimh packs.... the setup will be all different. We have a really good class of novice and stock trucks here too so it's some good fun racing. Last week we had 10 novice and 10 stock truck...
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
06.18.2007, 05:52 PM
Nice! That jump/corner after the triple is what killed me! Now, I can go full bore. :) Not really, but should be easier.
I might just give HH a call to see if they still have the Losi on the shelf and a replacement shock cap for my poor CRT.5. Man that thing is fun on the track!
AAngel
06.18.2007, 08:04 PM
Brian, not to get off topic, but where's the tread on your crt conversion?
06.18.2007, 08:43 PM
The CRT.5? Um, right here.
