I don't know if it would work on this size motor but I use a locktite for pinions on my 1/18 motors. Would that work on these? I just hit the pinion quickly with a heat gun and it pops right off.
I find it impossible to run without a flatspot... before I make mine.. I tape up the whole motor, and put the shaft on a vice... and I use a metal file.. seems to make a nicer flat spot that a grinder/dremel....
That would almost be called manual labor. blasphemy.
Thats easy, the whole shaft. You never know when your gonna have to put a pinion on backwards or if its a fat one or skinny one, the set screw could wind up any where.
i agree its best to flat the whole shaft otherwise you will create a weak point in the shaft that would take most of the deflection under high lateral loads.
I make a flat spot for most of the shaft, but I leave the end bigger, just in case the setscrew gets loose. That way the pinion can't go flying off
That's a pretty darn good idea Finnster! I know I recently had a pinion fly off on me... didn't wait long enough for lock tight to harden and/or I didn't tighten th set screw enough.
