BlackedOutREVO
11.13.2007, 07:07 PM
Originally Posted by Finnster View Post
I make a flat spot for most of the shaft, but I leave the end bigger, just in case the setscrew gets loose. That way the pinion can't go flying off
Yeah, that is a very good idea!
Patrick
Patrick's Avatar
11.13.2007, 11:53 PM
I use a grinding stone on the dremel and leave the last mm or 2 as well so the pinions can't come off. The pinion came loose once or twice with my fiegao, but I didn't loose the pinion because of the end being bigger.
With my neu I think I may have done the flat spot a bit better (still with the lip at the end though), because I haven't had a loose pinion in the last 6 months I've had that motor, I don't use loctite on the set screws.
I've put pinions on the shaft with the set screw facing both ways and the lip at the end hasn't gotten in the way.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
11.13.2007, 02:22 PM
a keyway and a set screw would work best.. but that's a real pain in the *ss to do... too much work..
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
Electric Dave
11.13.2007, 08:22 PM
I've used the "dimple" method on my motors. If I took a photo you guys would laugh...it's a miracle the shaft hasn't broken given how deep I've drilled! Anyway for my next motor I want the flat spot. If any of you have the perfect method, post it, including any bit part numbers or whatnot. I'm happy to buy the right tool/bit.
Also, maybe as a value add, RC Monster could offer it for a fee with any new motor purchase - hint - hint...I'd certainly pay $10 extra to have it done right.
