Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
year1camaro
year1camaro's Avatar
01.08.2009, 11:59 PM
I was wondering how it all went with your conversion. I flexed my chassis and took out second gear on the spur,,, did you have those problems? I made an upper support to help cure the problem. Mine used to be Nitro, but you can't run it anywhere public cause there loud so I decided if I'm gonna have fun with this I gotta go brushless. I added some Ofna foam trued tires. I also cut my own motor mount. Here is a couple pics of the project.
01.09.2009, 12:07 AM
awesome ^^^^^^^^^^
did you true the ofna tires or did they come that way? I'm too lazy...
year1camaro
01.09.2009, 12:11 AM
awesome ^^^^^^^^^^
thanks
Ofna True Blue they call em,,, they're done already. nice and sticky, ofna said they should handle the speed, we'll see,
01.09.2009, 12:13 AM
I see I'm not the only one who likes those upper-decks. They really stiffen things up to help prevent flexing at all. Maybe still some torsion flex, but not nearly as much as f/r flex.
That deck should help stripping the spurs, but I would maybe add an extra plate that goes under the motor mount and CD area so stiffen it a bit more. Since the motor mount and CD mounts are not on the same "plane" ANY flexing will eat spurs. Probably why Mike's mounts are so popular...
Nice body on that!
dangerwr
01.09.2009, 12:30 PM
Nice body on that!
Which body is that? 1/7th??
I just received my DM-1 Spec last night and will be starting my conversion soon. I ordered the Ofna center spool and looks like it is specifically design to fit Ofna's spurs--does anyopne know?
year1camaro
01.09.2009, 01:14 PM
Yes,,it's the DMone Pro Kit....comes with body. Not sure on the spurs,,,but i'm gonna guess, yes.
01.09.2009, 01:20 PM
The Ofna single speed spur setup uses the 51T spurs: http://www.rc-monster.com/proddetail.php?prod=ofn30110
Luckily, I happen to have a few from the old days when using an emaxx tranny with strobe slipper setup was common.
Note about the Ofna single speed kit: It does not come with support bearings or outdrive cups so you need to get those seperate. Also, my kit did not come with the needed grub screw, which is 5mm.
year1camaro
01.09.2009, 02:12 PM
I'm not gonna be needing that stuff, Im using the clutch bell and the two speed trans in my setup with mechanical brake. But thanks anyhow.
dangerwr
01.10.2009, 03:05 AM
Ok. I am up to speed with the 51T spur--I will have to order one (or two!). As far as the center single-speed kit I installed that today (I will post pics soon). I used the center shaft from the 2-speed and seems to work fine--this way the bearings and out drives fit without issue. What is with the missing 5mm set screw?
Thanks for your help. Cheers!
year1camaro
01.13.2009, 12:30 AM
I got a few more things done over the weekend. New Feigao 540XL is the first motor I'm tryin out.(we'll see if it sticks) The stock clutch bell and 2 speed gears are mounted to it. I made the radio tray up to support the receiver, antenna and brake servo also, one bolt and it swivels out for cleaning.
I'm still waiting on six 30C 5000mah lipo cells to come in the mail. I'm gonna start it out on four cells and see what happens. I was wondering if anyone out there tried to run the DM brushless with the 2 speed? Any suggests, complains or praises?
I know the one down fall is no reverse, but I'm not sure how important that will be for parking lot racing. Thanks for comments and suggestions in advance.
SidewaysLS4
01.09.2009, 03:18 PM
Nice rides guys!
BlackedOutREVO
01.19.2009, 02:46 AM
What/who makes that spool?
And any tips on building this puppy up? My buddy is building one currently, and wants a speed machine, CC combo, 220 KV, 5s, and a zippy 4000 mah batt
dangerwr
01.19.2009, 10:01 PM
Ofna makes the center spool. There is a picture and part# back around page 8 or 9. Let me know if you can not find it and I will look it up . . .
ssspconcepts
ssspconcepts's Avatar
01.19.2009, 10:15 PM
If you want a single speed center, then you will need these parts. You can either buy them separately or use parts from the stock 2-speed to build the center:
http://www.nitrohouse.com/catalog/pr...ducts_id=12086
http://www.nitrohouse.com/catalog/pr...ducts_id=11306
http://www.nitrohouse.com/catalog/pr...ducts_id=11016 (you can ditch the shaft that comes with the silver aluminum spur mount)
http://www.nitrohouse.com/catalog/pr...ducts_id=10760
http://www.nitrohouse.com/catalog/pr...ducts_id=12091
You will also need a 13mm long piece of 8.1mm inner diameter steel tubing and a couple of 8mm steel washers because the 8mm center drive shaft does not have bearing stops milled on it to prevent the shaft from sliding back and forth.
BTW...this thing is nuts on 5S. I had a hard time keeping the tires from spinning with my 5S/2200kv. I couldn't imagine 6S.
finfin
01.20.2009, 09:54 PM
Very nice car...
How many height of chassis from ground? How many mm. is it different from Ofna Ultra GTP?
