DickyT
02.14.2008, 11:16 AM
Thank man. The truck will be a basher that might see some track time if I can find a gorup that will let me run with them. The local tracks are nitro based with no BL classes. And the nitro guys do not want to run against electrics.
I have another set of Wabash that I need to dye and mount a set of bowties or crime fighters too for dirt. The road rages are just for my condo and work parking lots.
I put the center diff in so it is not a wheelie machine. bashing or not i like to have all 4 on the ground unless jumped.
86ragtopstang
02.14.2008, 11:23 AM
i just noticed a somewhat odd issue with my revo project. when you move the truck forward wheels dont turn. push it backwards and they do. is this a brake issue?
02.14.2008, 12:10 PM
So the wheels slide when pushing the truck forward, but roll when pushing it backwards?
86ragtopstang
02.14.2008, 12:13 PM
yep. that is exactly what they do.
02.14.2008, 12:16 PM
Do you still have the two speed tranny? That sounds like the OWB doing its thing...
86ragtopstang
02.14.2008, 12:20 PM
im not sure. been quite some time since i did any major work to the truck.
DickyT
02.14.2008, 12:31 PM
agreed, sounds like the owb. I have mine removed. the truck slides in both direction when pushed unless the surface is grippy. then it wil click click click and roll. I can't believe how hard it is to turn this motor over while powered off. compared to my mamba that spins freely it almost feels brushed with strong magnets.
pipeous
5th Scale Guy
pipeous's Avatar
02.14.2008, 02:17 PM
The colors look awesome dude. And I want those rcm stickers ;). I didn't mean to scare you off 5S, I am just one of those lean to the side of caution guys in case, but if it's a griffin modded esc, I bet he tested 5S. My bud is running his on 3S and it goes good.
When I got my plettenberg I thought the motor was pooched it was so hard to turn.
DickyT
02.14.2008, 04:07 PM
Actually I'm glad you made me think twice. I would have been upset if I ordered 5s and it could not handle it. the only thing I need to get extra now is an external LVC. Artur said the MM will not function on 5s using built in lvc.
DickyT
02.15.2008, 09:12 AM
Just ordered a hyperion eos0610i charger, true rc 5s 8000mah lipo, battery bunker, and li-saver lvc for cars.
now the fun of waiting on the brown truck....
electric
electric's Avatar
02.15.2008, 11:17 PM
great build of the car, wanted to no what LVC and will you be able to run 5s with no modifications.
thanks for help
DickyT
02.16.2008, 12:53 AM
thanks for help
Thanks. When finished it will have an MMM when released. In the interim I'll be using a GriffinRu stage 1 modded MM with ubec and a car version li-saver from the rc-monster store.
http://www.rc-monster.com/proddetail...rod=lisavercar
griffinru mm = toast :(
DickyT
griffinru mm = toast :( - 02.21.2008, 08:00 PM
I got home, wired in the li-saver, plugged in a 2s lipo to check the system. it armed all worked well.
I plugged in my 5s pack, flipped the power switch on the MM and it smoked as soon as it armed. I didn't even get to pull the throttle.
back to a stock MM and 12 old nimh until my b-day @ the end of march...
pipeous
5th Scale Guy
pipeous's Avatar
02.21.2008, 08:09 PM
oh wow that truly sucks.
DickyT
02.21.2008, 08:30 PM
yep. such is life. you play with fire you can get burned. I got burned. life would be no fun for me if I did not push limits, and I have always loved computer overclocking. an overclocked esc seemed fun to try.
