johnrobholmes
johnrobholmes's Avatar
11.17.2007, 09:38 PM
+1 on getting rid of tamiya plugs. Junk Junk Junk
squeeforever
squeeforever's Avatar
11.17.2007, 10:00 PM
Yup. Atleast put TRX connectors on it. Or better yet, none.
11.17.2007, 10:12 PM
None would be a little cheaper, but offering it with different plugs would be better for people who are scared of soldering, or who are from the Traxxas forum (meaning they would wire the plug on the wrong way and blow up the esc & batteries; dont laugh, I've seen people do it several times over there....).
cart213
cart213's Avatar
11.17.2007, 10:15 PM
Nah, they'll want it to be plug-n-play, so they won't leave the connector off. A Deans plug would be nice.
Edit: You beat me to it, neil.
ib4200
nota newb
ib4200's Avatar
11.17.2007, 10:20 PM
lol. i cant even think of how you could do that.
  Send a message via AIM to ib4200
11.17.2007, 10:21 PM
Quicker than a bolt of lightning, is I. Batteries are often offered with different or no plugs, so why not escs too? Then I can re-use my 5.5mm gold jobbies no whatever Novak or CC etc bring out next.
Its simple, you cut off both wires at the same time (causeing a short circuit for good measure), then you forget which way around the tamiya plug went, have a guess rather than taking 30seconds to find a picture on-line, or looking at the other esc/battery plugs you have near by, then you solder it on wrong. Next you plug in your rewired gear, flip the power switch, and watch the pyro-technics....
ib4200
nota newb
ib4200's Avatar
11.17.2007, 10:36 PM
i did see sombody with melted tamiya plugs that couldnt disconnect the battery and they went to cut the wires and the cut both at the same time lol and it made lots of sparks but you would have to be really stupid to not be able to match up the colors when re-soldering it
NovakTwo
Senior Strategist
11.19.2007, 01:52 PM
Thanks to all of you who have offered comments and suggestions. I will share your inputs with our design team.
One note about the Tam battery connectors---they are necessary for our own final system testing procedures. We understand that most users replace them immediately with much better, low resistance connectors.
Novak Electronics, Inc.
BP-Revo
BMW M Power!
BP-Revo's Avatar
11.19.2007, 04:11 PM
At least you guys still warranty the part after we replace the plugs... unlike Traxxas...
Sower
Sower's Avatar
11.19.2007, 04:29 PM
Wow, this is a great thread - nice to see Novak jumping into the fray! What a great time for 1/8 brushless R/C
johnrobholmes
11.19.2007, 02:06 PM
How about you change the plugs on your testing equipment? Or make a harness? I would rather get an ESC with no plugs than tamiya plugs.
ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
11.19.2007, 02:07 PM
+1
if you plan to build and test higher voltage systems (6s+) and still plan to keep the tamiya connectors... and not have them fuse together... well, good luck.
Eflite Blade 400 heli on 3s
neweuser
neweuser's Avatar
11.19.2007, 02:17 PM
I like the harness idea. It only makes more sense. It would satisfy both worlds. I also would like a higher voltage ESC that is more dependable for a heavier vehicle. I think we all have been waiting for it. One reason why I went from an HV to a Sensorless system. That, and even with me, I followed the directions on the HV and still thermalled. I even geared it to the lowest. Other than that, I would love to see Novak come out with something.
Serum
Serum's Avatar
11.19.2007, 02:21 PM
Yeah, in my opinion the tamiya plugs are a waste.
I know the hvmaxx key-feature is 'direct drop in' but according to the manual you have users solder on the HVmaxx (to make the battery setup parallel instead of series) but the tamiya plugs are neglected. Not even a hint for the unknown. they are no good for 1/10th onroad cars, so leave alone monstertrucks who are 3 times as heavy.
This is no ranting, just a thing i would like to see changed.
On a stock maxx this is the first item to replace, so on a brushless maxx it should be replaced by standard.
glassdoctor
TEAM FUSION
glassdoctor's Avatar
11.21.2007, 01:23 PM
here's a scan of the "article" in RCCA.... that's all we have right now that I have seen.
http://i163.photobucket.com/albums/t...rsion_0002.jpg
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
