You mean the ones in Snoop's post? I believe he machined those parts himself- the pvc pipe trick a few posts before that is just as good ( if less attractive ).
Yesterday 07:30 PM
+1
They hold up with NO trouble at ALL!!!!!
Duh, I broke the little plastic ring that go in the bulk and over the pinion input!
I made a peice of lexan to stop the diff moving up and down!
That's correct Niel
I just have to get a piece of nylon or alloy for the front support
I dont think he had to do anything as such- at most a little filing for clearance incase they are tight ( like rpm arms tend to be sometimes ), but nothing 'special' which requires loads of work or special treatment. Just buy some and have a fiddle, you'll soon workout if anything needs doing.
