Xray Xt8
entjoles
Xray Xt8 - 12.29.2007, 10:03 PM
i am in the process of selling my revo stuff and just put my electrics in this truggy i got on ebay from mailman
xray xt8 with rc-monster motor mount
mm, 4s, 9xl
16/48
temps were 85-90*f in a 50*f underground garage
Q?...can i go to a 18 tooth pinion??(what i have)
i plan on using this for double duty, brushless and nitro so i will be making a new plate to put the electrics on to ease swapping back and forth
i will post a few pics soon, but they arent the final set-up, i just put it together and had to test
set up help for diffs and suggestions are welcome
heres a quick vid...........very low traction on dusty cement..maybe 35mph??
http://www.youtube.com/watch?v=nCAuVhs-w2o
squeeforever
squeeforever's Avatar
12.29.2007, 10:25 PM
Your gonna have to compromise if its gonna pull double duty. The diffs, setup correctly, aren't gonna be ideal for both. Its one or the other. Usually brushless is gonna require a good bit heavier fluid in the center, and slightly heavier in the front and rear.
entjoles
12.29.2007, 10:30 PM
true, but i have to remove the diff anyway to change it back to nitro, and it will only be ran nitro a one weekend a month
i was thinking since i have some , i would try 30k in the center with brushless
i dont know whats in there now
entjoles
12.30.2007, 01:08 AM
maybe i should get a second set of diffs??
heres some pics
i just have this thrown in here for testing, i will be makeing a new esc. plate to mount it farther back and look a little more tidy
and will upgrade to the MMM when it comes out, this is my winter project so i will post some new pics once i get it finished
ncalenda
Need for Speed
ncalenda's Avatar
12.31.2007, 02:00 AM
What would you recommend? I was going to try 7/15/7 (stock is 7/10/7)/
Are you thinking maybe 10/20/10??
I bought a 2nd center diff so that I could test diff ones.
  Send a message via AIM to ncalenda
squeeforever
12.31.2007, 12:54 PM
I would say start at 30 in the center.
ncalenda
Need for Speed
ncalenda's Avatar
12.31.2007, 02:43 PM
If I go with 30 in the center, will that put too much stress on the diffs or axles?
tallyram
tallyram's Avatar
12.31.2007, 11:57 PM
i started out with 7/30/3, but i drive on a tight track so i went down to 10 in the center. the truck doesn't want to wheelie as much in certain parts of the track and it has more off power steering!
luxury!
  Send a message via AIM to tallyram
entjoles
01.01.2008, 12:50 AM
thanks, thats sweet, i can run both with out much grief then
btw.. what do you run in your shocks
Patrick
Patrick's Avatar
01.01.2008, 01:05 AM
I've tried 10k and 30k in the center diff in my brushless truggy. I think I liked 10k a bit better for racing, but I'll probably try 20k or so next. I think you can find find an oil that will be ok for both.
squeeforever
01.01.2008, 01:30 AM
The main thing is what kind of diffs you have. 4, 6, or 8 spyder. The more spyder gears, the lighter the fluid you can run.
entjoles
01.01.2008, 01:38 AM
patrick.....omg i just noticed your avitar
whats in that dogs mouth
oh and thanks, ill give those a shot, brushless will mainly be bashing and track days, and maybe racing club races, but i want to run the summer series here and i have to run nitro there
Patrick
Patrick's Avatar
01.01.2008, 01:43 AM
Your the second person to ask what's in his mouth.
He doesn't have anything in his mouth, he's just resting his head across his leg. (his front paws are white)
ncalenda
Need for Speed
ncalenda's Avatar
01.02.2008, 05:46 PM
This is in the xt8, so 4 spiders.
I was going to start with 10k, but then jump to 30k, and then back to 20k. I want to see which one I like.
entjoles
01.02.2008, 07:18 PM
http://www.teamxray.com/teamxray/pro...w%20XRAY%20XT8
it says 6 gear
it wasnt bad when i drove it , so i will probably wait till spring to get some testing in
edit ..... 4 gear ...sorry
http://www.teamxray.com/teamxray/pro...20Gears%20(2+4)
