MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
01.16.2008, 12:01 AM
I have run a 12s in my mainly stock pede for a few dozen packs and it is great. On 3s with 15/56 gearing it has plenty of speed and I get better than 30mins of bashing/speed runs on a 4000mah 20c 3s lipo. I would recommend it, just put a clip on heatsink on the motor.
With what sort of spur is that? Is that a jato spur and do those just bolt on?
01.16.2008, 12:04 AM
Yep, the jato spurs will just bolt on, and you can use std 32p pinions with the .8mod jato spurs. Definately a cheap upgrade. The cover will not fit on with the jato spurs, but I run mine in sand and gravel and it shows hardly any wear. I even half stripped a few teeth off the spur (the motor came loose) and just reset the correct mesh and am still running it!
bluonyx
Here's a place that sells them, 6L - 12L's for $59.99. I've only used them once but didn't have any problems.
http://www.offshoreelectrics.com/products.php?cat=42
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
01.16.2008, 12:51 AM
Thanks guys. The 9l has been ordered from offshore electronics with stock 540 size shaft which should make things a bit easier. The L can is only 57g heavier the the s so my mate went 9l.
Thanks guys for the help. Should be fast once he gets an MM and battery to run it on.
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
01.16.2008, 09:15 AM
offshore is a good company. I've ordered from them several times.
01.16.2008, 11:15 AM
I try to buy most of my boat stuff from them. Steven has not let me down yet, so I always recommend him for certain items, especially the stuff that Mike does not carry.
neweuser
neweuser's Avatar
01.16.2008, 11:37 AM
Remember, even if Mike does not seem to carry it, he most likely can get it.
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
02.11.2008, 08:11 AM
We put the 9l in the stampy tonight and we got about one and a half minutes out of it before it stripped the idler. New idler for his andmy stampy as I stripped mine on the weekend with just the stock xl5. On 3s the 9l is crazy powerful. He almost did an on the spot backflip just trying to start the thing.
neweuser
neweuser's Avatar
02.11.2008, 10:04 AM
RC Monster of course! :P
