sikeston34m
sikeston34m's Avatar
02.09.2008, 02:05 PM
On mine I used a Ebec, when it blew. When the brain was taken out there was a mess on some of the chips. It looked burn at first, but it was just nasty flux.
Those caps are small huh. The heatsink just pops right off, as it's just sitting on a thermal pad.
Yes, these caps are small and overloaded IMO. It's pretty obvious when the power lead insulation melts like this. They were running very hot.
So what blew on yours?
rschoi_75
Certified Spaceball
rschoi_75's Avatar
02.09.2008, 02:11 PM
I was running an external bec, which also fried at the same time the esc did. I think it may have been partially my mistake since I forgot to disable the internal bec. whoops.
rcm xt8
rcm xb8
rcm crt.5
sikeston34m
02.09.2008, 02:13 PM
Hmmmm............
What voltage was your external BEC set at?
02.09.2008, 04:40 PM
hey, do you guys think this esc could work with a large outrunner in my direct drive tmaxx?
rschoi_75
Certified Spaceball
rschoi_75's Avatar
02.09.2008, 05:08 PM
6v. its was the koolflight ubec from here.
rcm xt8
rcm xb8
rcm crt.5
sikeston34m
02.09.2008, 05:45 PM
Ouch!
With the External at 6v and the internal at 5v. This is probably what took them both out.
The external probably went first, then the shearing heat of a 5S battery set in on the internal BEC.
02.09.2008, 05:58 PM
si there a way to disable the internal bec?
sikeston34m
02.09.2008, 06:00 PM
Yes. All you have to do is lift the center "red" wire from the ESC to receiver plug.
02.09.2008, 06:04 PM
just cut it out? and can someone answer my question, will this esc work for my t-maxx on 6s? (large outrunner)
rschoi_75
Certified Spaceball
rschoi_75's Avatar
02.20.2008, 07:25 PM
any news on this?
Hey sike... this is off topic, but I just saw a little show on your hometown. Looks nice! They showed the restaurant where the waiters throw dinner rolls at you... looked like fun and good food. It makes me hungry for some chicken fried steak. mmm.....
rcm xt8
rcm xb8
rcm crt.5
sikeston34m
02.20.2008, 07:30 PM
any news on this?
No new yet. I need to lift that brain board and get a better look. I have a feeling the brain board might be bad though.
Aaaah, you must be talking about Lamberts. We have ate there several times. There's a guy that comes around pushing a cart full of fresh out of the oven rolls. He yells "Hot Rolls!!!!!!!", you hold your hand up and he throws one across the room at ya. LOL
They have some great food there. It's nicely laid out too.
lutach
lutach's Avatar
02.20.2008, 08:01 PM
Sike,
Are you going to post pics of the brainboard here?
sikeston34m
02.24.2008, 08:56 PM
OK, I got the Brain Board lifted.
Here's a picture.
OK class! Quiet down! Can anyone guess what's wrong with this picture?
That's any easy one huh? OK, is there an advanced student in here that can tell me why this happened?
sikeston34m
02.24.2008, 09:17 PM
Does anyone have a Brain Board that would make a good transplant?
GriffinRU
02.29.2008, 04:49 PM
Here's a picture.
Looks like inductors, do you see any coils inside?
All the rest is clear Fet's drivers with bootstrap caps and diodes.
Also looks like you lost couple via's in process of taking it apart, not good, but can be fixed.
I can try to fix it for you, but later in April :(
