01.26.2008, 05:14 PM
ill take one!
01.27.2008, 12:40 AM
Hey guys, I'm sorry to say that I won't be able to get anything done for a while. I am working out of town for the next couple of weeks, but the good thing is all my parts should be in when I get home
BTW, what springs are you guys running in your E-revo's? I have the orange springs up front with tan springs in the rear, and 60 wt shock oil from when it was nitro. I never got around to trying anything else when I was running it with the twin tranny, but thought about going for green or gold in front, with silver in the rear. I think this should be close for bashing/jumping with the extra weight of the e conversion. Any thoughts?
01.27.2008, 10:11 AM
those springs should be ok, i used purple frt and rr on my g3r revo and it was great with 60wt oil, but it was heavier then the stock chassis conv.
also something to think about,i noticed that no matter how stiff i made it , it wouldnt come back up, i had to fit my suspension arms , they were binding and i had to ream the pin holes and lightly sand the end of the arms to get free movement, no binding at all after i did this , w/o shocks i could lift arms and they would drop free as could be, no resistance at all
01.28.2008, 12:12 AM
Yup, I noticed that too after I had run my revo for 3-4 gallons. I reamed all the pin holes and polished the shafts. The suspension was really free, at least for a while. I usually run in a big sandpit, so my revo takes a lot of abuse.
01.28.2008, 01:55 AM
Here is a vid of my revo at the sandpit from last summer. It's nitro  but this is what I am building it for, lots of abuse Desert Rat Bash Movie
01.28.2008, 03:52 AM
Originally Posted by entjoles
...also something to think about,i noticed that no matter how stiff i made it , it wouldnt come back up, i had to fit my suspension arms , they were binding and i had to ream the pin holes and lightly sand the end of the arms to get free movement, no binding at all after i did this , w/o shocks i could lift arms and they would drop free as could be, no resistance at all
Wonder if it's from slightly bent pins? Mine are still free but haven't taken many large jumps so I'm sure that helps. Time for a Ti pin upgrade maybe?
01.28.2008, 11:47 PM
My pins are straight, they just get packed full of sand and get all scuffed up.  So who makes a TiNitrate coated pin set for the revo? I don't think I need actual titanium pins, but I'd love a set of TiNi coated ones. I used to eat up SS shocksafts in the sand before I got the GTX shocks, now they last forever.
RC-Monster Captain
01.28.2008, 08:05 AM
Ummm.....you know, guys, I have a slipperential in my SuperMaxx, but I want to taste my Maxx with a centerdiff. I've been looking around for someone to make me a nice centerdiff mount with drive shafts, but no luck.
This one is made by Mike a very long time ago, and it has a few flaws that holds me from using it. It's evident that his work on the slipperential is lightyears ahead of his work on this thing.
I hope you can hear me, Mike. I want a damn centerdiff for the SuperMaxx ( with slipperential quality).
Nice to meet you!
01.28.2008, 09:25 PM
Here! Here! I am waiting for my direct drive units too! And I am in the process of building an e-revo on a gorillamaxx chassis...so I will take one of those damn slipperential things too!
01.28.2008, 11:54 PM
you could always get some compressed air cans and just spray the dirt off and make sure to really spray those tight areas. always works for me
01.29.2008, 12:18 AM
I use my air compressor after every run, but I think that is what packs the dirt/sand into the suspension pins. The only cure I've found is to take the suspension apart every once in a while and clean it.
01.29.2008, 06:33 PM
This happened with my revo too, if you cbf removing the pins and cleaning it properly, a spray with some silicone lube with one of those thin directional tube things around the hinge pin joints makes about 1000x better - its just dirt etc. getting trapped. Or you could take it a step further: my brother got a heap of tiny ball bearings and completely bearing-nated his savage suspension (shocks and inner/outer swingarms at least) and it had unbelievably smooth suspension - zero difference if you pushed it down a let it come back up compared to lifting it and letting the weight of the vehicle compress the suspension.
Be careful here around bearings (and not crazy bearing suspension bearings, wheels any other bearings, motor and wheel for example) compressed air will force little bits of dirt into your bearing seals - I learned this the hard way. Air compressor is great with a spray bottle of metho for cleaning your nitro vehicle, now I always do anything near a bearing with a paper towel though.
03.12.2008, 11:33 PM
OK, I finally got a couple of days off and got my Evo together. Still need to do a few little things like clean up the wires some more and play with the settings on the MM. The 50% brake setting gives instant endo's I found out, very powerfull brakes. I am running 50% punch control as well, and really like the smooth power delivery, and it will still wheely on demand. The Trakpower batteries are awesome, they hold their voltage right until the cutoff, and I have it set at 3.2v/cell as an extra safety margin. I ran 4 packs so far, and the temps were really good. 120-140 on the MM esc with no fan, 90-105 on the motor and room temp on the batts. I am running the 14 tooth pinion for now, can go up if I want to go faster. Speed calc says 37-38 MPH, which looks about right.
Differential Ratio: 4.3
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 14
Total Voltage: 14
Motor KV: 2084
Tire Diameter (inches): 5.8
Tire Ballooning (inches): .25
Motor Current Draw: 0
Motor coil Ω: 0.0073
Spur/Pinion Ratio: 3.29 : 1
Total Ratio: 14.12857 : 1
Tire Circumference (inches): 19.79 inches (502.72 mm)
Total Motor Speed: 29176 RPM
Vehicle Speed: 38.7 mph (62.17 km/h)
Effective Speed Rate: 2.76 mph/V (4.44 kmh/V)
Estimated Adjusted Speed: 37 mph (59 km/h) - 5% loss
Effective KV Value: 2084
OK, now for the pics
Not real happy with the wiring yet, like to get it a little neater.
Had to clearance the hump a bit to fit the smaller pinions.
I love how simple this setup is.
03.12.2008, 11:41 PM
Pinion came off during first run, I forgot to lock tite it
Luckily it stayed on the chassis and I didn't have to go looking for it.
Also ground a fair bit off the ends of my wing doing wheelys
I am really happy with the truck overall, now I just have to get some more batteries.
01.29.2008, 05:54 PM
IMO you should do that anyways... haha. your lucky you havent sucked some real fine sand into your engine. i know my filter let through some really fine dust and it ruined my engine...
