supermaxx
07.15.2008, 08:29 AM
Real nice conversion Jordan, that neu motor does must weight alot, doesn't this strain alot on the single carbon fiber mount?
Maybe making another sort of mount on the back of the can?
jordan...
one.five.two.seven
07.15.2008, 08:35 AM
Thanks for the comments guys!!
@rommel, its not running yet, hopefully these 2nd batch MMM's aren't too far away...
@supermaxx, thats a good point, i am going to make a brace under the back of the motor, but i need to get the driveshafts first to make sure i have enough clearence. It is surprisingly rigid though, with only one of the plates, it was flexing all over the place, but with two i can drop it from about 3 feet and there doesn't seem to be any flex in the motor mount.
thanks again
jordan
TruckBasher
TruckBasher's Avatar
07.15.2008, 08:36 AM
This limits you to one pinion size right?
Looking great..I've been wanting to do something like this for my maxx but no tools and materials to play with....
E-Slayer direct drive to diff
jordan...
one.five.two.seven
07.15.2008, 08:47 AM
At the moment, yes it does. I'm not too fussed about that, it'll just be a basher. Nothing the trusty dremel can't handle if i do need to change gearing though
It wasn't too hard to do, all it took was a dremel and a couple of files... oh, and alot of time
TruckBasher
07.15.2008, 08:51 AM
Hmmm my dremel is coming so i guess if I can find a good CF of Alu seller I will be in business....
Good thing we are both bashers :)..
jordan...
one.five.two.seven
07.15.2008, 09:01 AM
Sweet, definately post some pics if you get some custom work happening. I got my cf from Fullforce RC
TDC57
TDC57's Avatar
07.15.2008, 06:40 PM
Dammmm Jordan..
This the best GM I have ever had the pleasure of seeing, great update!.. I can’t wait for the video. As always just an absolutely outstanding job Sir..
You just single handed kick my two GM builds rite out of the water..
Great job jordan...
Nothing!.. Hahahahaaa..
jordan...
one.five.two.seven
07.15.2008, 09:32 PM
Thanks alot Shaun
...and i wouldn't say that, your Gmaxx's work
have a good one
jordan
drkros3
07.15.2008, 09:56 PM
what batterys are you going to be using?
jordan...
one.five.two.seven
07.15.2008, 11:16 PM
I'm going to be running 2 3s packs in series for 6s. Definately 5000mah and probably 25c. I'm thinking along the lines of Flightpower or Neuenergy etc. at the moment. I've found a place to get Neu 3s 5000mah 25c packs for $130 each, pretty good deal i think.
drkros3
07.16.2008, 12:55 AM
wow that thing is going to be rip lol. cant wait for a vid.
oh and seeing this thread has got me thinking about maybe getting a neu motor. cause im running a lot less kv then you are on 6 cells and its the limit of the motor. (or i dont really want ot push it any more)
jordan...
one.five.two.seven
07.16.2008, 01:16 AM
i see what you mean, 6s on this motor means roughly 50,000rpm. Which i think is comfortably under the 60,000rpm limit of the Neu motors. Reason i chose this kv is so i could get the max performance out of 6s, because i don't want to be spending big $$ on heaps of lipos and HV ESC's.
drkros3
07.16.2008, 01:21 AM
haha yah thats another reason. i can only go up to 80 amps and 6 cells lol. and i think i might be at the limit of my gearing. cause i know if i gear it for any faster it well go over 80amps. but at least the esc well shut down befor it goes over 80
TDC57
TDC57's Avatar
07.17.2008, 03:08 AM
So when is "D" day Jordan (??)
jayjay283
jayjay283's Avatar
07.17.2008, 04:59 AM
lol Jordan, is that a Neu or a 8 cell maglite strapped on that badboy !! Sweeeet
