02.02.2008, 10:40 AM
Ok decoded the settings DB as best I can for now - I need to look at the voltage cutoff as picing up multiple settings - here it is for now:
controller.name version_customer beta production comment gui_name setting_value.name help
Monster Max (F310C) 1.17 No Yes Mamba Max, Mamba Max Pro, Monster Max, Sidewinder Throttle Curve LineColor na
Monster Max (F310C) 1.17 No Yes Mamba Max, Mamba Max Pro, Monster Max, Sidewinder Throttle Curve GridColor na
Monster Max (F310C) 1.17 No Yes Slider Input 9 CH_NUM na
Monster Max (F310C) 1.17 No Yes Cutoff Voltage No Cutoff Best for racing with top quality discharge NiMH or NiCad packs. DO NOT USE this setting with Lipo packs
Monster Max (F310C) 1.17 No Yes Cutoff Voltage 5.0V Use when running a battery pack with 7 or more NiCD or NiMH cells.
Monster Max (F310C) 1.17 No Yes Cutoff Voltage 6.0V Use when running a 2 cell LiPo battery pack.
Monster Max (F310C) 1.17 No Yes Cutoff Voltage 9.0V Use when running a 3 cell LiPo battery pack.
Monster Max (F310C) 1.17 No Yes Cutoff Voltage 12.0V Use when running a 4 cell LiPo battery pack.
Monster Max (F310C) 1.17 No Yes Cutoff Voltage Auto Li-Po Use this for all applications where you are using Lipo batteries. When selected, the controller will detect the number of Lithium Polymer cells in series in your battery pack, and set the cut off voltage to 3 volts per cell. When you plug the battery pack into the controller, after the initialization tones the controller will flash and beep the number cells it counted, so you can confirm the controller setting. If the cell count is incorrect, make sure your batteries are charged and the correct cell count is flashed BEFORE flying. Note: Do not use Auto Lipo with NiMH or NiCad cells.
Monster Max (F310C) 1.17 No Yes Brake Amount 10% The brake will engage at a strength 10% as strong as the strongest brake setting.
Monster Max (F310C) 1.17 No Yes Brake Amount 20% The brake will engage at a strength 20% as strong as the strongest brake setting.
Monster Max (F310C) 1.17 No Yes Brake Amount 25% The brake will engage at a strength 25% as strong as the strongest brake setting.
Monster Max (F310C) 1.17 No Yes Brake Amount 30% The brake will engage at a strength 30% as strong as the strongest brake setting.
Monster Max (F310C) 1.17 No Yes Brake Amount 40% The brake will engage at a strength 40% as strong as the strongest brake setting.
Monster Max (F310C) 1.17 No Yes Brake Amount 50% The brake will engage at a strength 50% as strong as the strongest brake setting.
Monster Max (F310C) 1.17 No Yes Brake Amount 60% The brake will engage at a strength 60% as strong as the strongest brake setting.
Monster Max (F310C) 1.17 No Yes Brake Amount 70% The brake will engage at a strength 70% as strong as the strongest brake setting.
Monster Max (F310C) 1.17 No Yes Brake Amount 75% The brake will engage at a strength 75% as strong as the strongest brake setting.
Monster Max (F310C) 1.17 No Yes Brake Amount 80% The brake will engage at a strength 80% as strong as the strongest brake setting.
Monster Max (F310C) 1.17 No Yes Brake Amount 90% The brake will engage at a strength 90% as strong as the strongest brake setting.
Monster Max (F310C) 1.17 No Yes Brake Amount 100% The brake will engage at full strength.
Monster Max (F310C) 1.17 No Yes Brake Amount MINIMUM na
Monster Max (F310C) 1.17 No Yes Brake Amount MAXIMUM na
Monster Max (F310C) 1.17 No Yes Brake Amount INCREMENT na
Monster Max (F310C) 1.17 No Yes Slider Control
Monster Max (F310C) 1.17 No Yes Reverse/Brake Curve LineColor na
Monster Max (F310C) 1.17 No Yes Reverse/Brake Curve GridColor na
Monster Max (F310C) 1.17 No Yes Start Power Low Best for almost any application, and any battery type/capability.
Monster Max (F310C) 1.17 No Yes Start Power Medium Good for use along with high capability batteries, and light race cars, and some slow systems or rock crawlers.
Monster Max (F310C) 1.17 No Yes Start Power High You MUST have top quality batteries to get the most from this setting without the car stuttering if it's set up for high speed. Best used for very slow/heavy rock crawler set-ups.
Monster Max (F310C) 1.17 No Yes Reverse Throttle Amount 10% Lowest brake and reverse speed position - not recomended for fast cars!
Monster Max (F310C) 1.17 No Yes Reverse Throttle Amount 20% Low brake and reverse speed position - not recomended for fast cars!
Monster Max (F310C) 1.17 No Yes Reverse Throttle Amount 25% 25% available brake power, and 25% reverse speed. Good for low traction surfaces/offroad racing
Monster Max (F310C) 1.17 No Yes Reverse Throttle Amount 30% 30% available brake power, and 30% reverse speed. Good for low traction surfaces/offroad racing
Monster Max (F310C) 1.17 No Yes Reverse Throttle Amount 40% 40% available brake power, and 40% reverse speed. Good for med traction surfaces/offroad and onroad racing
Monster Max (F310C) 1.17 No Yes Reverse Throttle Amount 50% 50% available brake power, and 50% reverse speed. Good for med traction surfaces/offroad and onroad racing - best general setting for bashing
Monster Max (F310C) 1.17 No Yes Reverse Throttle Amount 60% 60% available brake power, and 60% reverse speed. Good for med traction surfaces/offroad and onroad racing
Monster Max (F310C) 1.17 No Yes Reverse Throttle Amount 70% 70% available brake power, and 70% reverse speed. Good for med traction surfaces and onroad racing
Monster Max (F310C) 1.17 No Yes Reverse Throttle Amount 75% 75% available brake power, and 75% reverse speed. Good for med/high traction surfaces and onroad racing
Monster Max (F310C) 1.17 No Yes Reverse Throttle Amount 80% 80% available brake power, and 80% reverse speed. Good for med/high traction surfaces and onroad racing
Monster Max (F310C) 1.17 No Yes Reverse Throttle Amount 90% 90% available brake power, and 90% reverse speed. Good for high traction surfaces and onroad racing
Monster Max (F310C) 1.17 No Yes Reverse Throttle Amount 100% 100% available brake power, and 100% reverse speed. Good for high traction surfaces and onroad racing
Monster Max (F310C) 1.17 No Yes Reverse Throttle Amount MINIMUM na
Monster Max (F310C) 1.17 No Yes Reverse Throttle Amount MAXIMUM na
Monster Max (F310C) 1.17 No Yes Reverse Throttle Amount INCREMENT na
Monster Max (F310C) 1.17 No Yes PWM Rate Dummy Default na
Monster Max (F310C) 1.17 No Yes MulValFore Default na
Monster Max (F310C) 1.17 No Yes Cutoff Voltage 18.0V Use when running a 6 cell LiPo battery pack.
Monster Max (F310C) 1.17 No Yes Cutoff Voltage 24.0V Use when running a 8 cell LiPo battery pack.
Monster Max (F310C) 1.17 No Yes Cutoff Voltage 30.0V Use when running a 10 cell LiPo battery pack.
Monster Max (F310C) 1.17 No Yes Cutoff Voltage 36.0V Use when running a 12 cell LiPo battery pack.
Monster Max (F310C) 1.17 No Yes Start Power Normal Good for use along with high capability batteries, and light race cars, and some slow systems or rock crawlers.
Monster Max (F310C) 1.17 No Yes Cutoff Voltage 4.0V Use when running a battery pack with 6 or fewer NiCD or NiMH cells.
dirt101
dirt101's Avatar
02.02.2008, 12:11 PM
does that mean a HV version will be available.
Dagger Thrasher
I have no idea what's going on
Dagger Thrasher's Avatar
02.02.2008, 12:23 PM
Thanks for that Arct1k...some very insteresting stuff in there! Mostly the LiPo cutoff values. Maybe they're just values for the existing HV controllers...I don't know. Might mean something though...
phildogg
phildogg's Avatar
02.02.2008, 12:49 PM
looks promising anyway.
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
DrKnow65
DrKnow65's Avatar
02.02.2008, 10:16 PM
Democrats are like the french, you can smack them around and they just cry, and do what you tell them. hahaha
Now if you go smacking around at a republican, you'd better be armed or have brought friends (republicans protect their right to bare arms for a reason).
I will confess that I think they have ALL gone sloppy though, and the party-line has gotten too light and thin for my liking. As for me and my household we will remain "cocked, locked, and ready to rock" to protect our own freedom.
02.03.2008, 09:36 PM
That is funny, wonder how bad french democrats are?!
Gun ownership is a good idea, especially for personal protection. But they are also a good investment as they rearely lose any value. And ammo is probably the best investment I have seen recently. Certain popular calibers have trippled in price over the last 5 years, and continue to climb.
I always work on the principle that I am ultimately responsible for myself and my well-being. So I have taken steps to ensure my safety, such as some training, research and firearm purchases.
"Look out for #1 and watch out for #2!"
Duster_360
02.03.2008, 10:48 PM
I have never understood why there is such a dedicated effort in the country to disarm legal, tax paying, law abiding citizens. The police, God bless them, pretty much all they can do is clean up the mess and give you a report to file for insurance (good luck with that).
If Billary gets elected be prepared! Hope for a Republican Senate or House or both to hold her in check. An ill wind will begin blowing on gun ownership. I have several NRA classifications and sleep with a 8shot 12ga Win Defender pump. If anyone doesn't understand what that noise is when I rack one into the chamber, they're getting ready have a really bad experience.
02.03.2008, 09:23 PM
Fixed my query... Software option in Monster look like the same as in Mamba under 1.17...
controller.name version_customer gui_name setting_value.name help
Monster Max (F310C) 1.17 Software
Monster Max (F310C) 1.17 Throttle Curve LineColor na
Monster Max (F310C) 1.17 Throttle Curve GridColor na
Monster Max (F310C) 1.17 Reverse/Brake Curve LineColor na
Monster Max (F310C) 1.17 Reverse/Brake Curve GridColor na
Monster Max (F310C) 1.17 Hex55 Value na
Monster Max (F310C) 1.17 MidCount Default na
Monster Max (F310C) 1.17 Cutoff Type Dummy Default na
Monster Max (F310C) 1.17 Brake/Reverse Type Proportional w/ Reverse Lockout For bashing or racing (may not be an allowed setting for racing). The controller must see 2 seconds of steady neutral throttle before it will allow reverse operation.
Monster Max (F310C) 1.17 Brake/Reverse Type Proportional w/o Reverse Racing setting - no reverse enabled at all.
Monster Max (F310C) 1.17 Brake/Reverse Type Forward to Brake To Reverse Similar to lockouttype, but no neutral waiting required before reverse is enabled. The controller will quickly brake the motor to near zero rpm, before allowing it to run in the opposite direction in order to save transmission parts.
Monster Max (F310C) 1.17 Start Power Low Best for almost any application, and any battery type/capability.
Monster Max (F310C) 1.17 Start Power Medium Good for use along with high capability batteries, and light race cars, and some slow systems or rock crawlers.
Monster Max (F310C) 1.17 Start Power High You MUST have top quality batteries to get the most from this setting without the car stuttering if it's set up for high speed. Best used for very slow/heavy rock crawler set-ups.
Monster Max (F310C) 1.17 PWM Rate Dummy Default na
Monster Max (F310C) 1.17 Drag Brake 0%, Disabled No drag brake - car will freewheel in neutral
Monster Max (F310C) 1.17 Drag Brake 10% Lowest drag brake setting - good for bashing, or low traction racing
Monster Max (F310C) 1.17 Drag Brake 20% Low drag brake setting - good for bashing, or low traction racing
Monster Max (F310C) 1.17 Drag Brake 30% Medium low drag brake setting - good for medium traction racing
Monster Max (F310C) 1.17 Drag Brake 40% Medium drag brake setting - good for medium traction racing
Monster Max (F310C) 1.17 Drag Brake 50% Medium/High drag brake setting - good for medium traction racing
Monster Max (F310C) 1.17 Drag Brake 60% Medium/High drag brake setting - good for medium/high traction racing
Monster Max (F310C) 1.17 Drag Brake 70% High drag brake setting - good for high traction racing
Monster Max (F310C) 1.17 Drag Brake 80% High drag brake setting - good for high traction racing
Monster Max (F310C) 1.17 Drag Brake 90% Very High drag brake setting - good for very high traction racing
Monster Max (F310C) 1.17 Drag Brake 100% Very High drag brake setting - good for very high traction racing
Monster Max (F310C) 1.17 Drag Brake MINIMUM na
Monster Max (F310C) 1.17 Drag Brake MAXIMUM na
Monster Max (F310C) 1.17 Drag Brake INCREMENT na
Monster Max (F310C) 1.17 Punch Control 0%, Disabled No accelleration limiting. The accelleration will be 100% determined by thr capability of your battery pack to flow power and maintain voltage.
Monster Max (F310C) 1.17 Punch Control 10% Very low accelleration limiting - good for 4wd on high traction surfaces
Monster Max (F310C) 1.17 Punch Control 20% Low accelleration limiting - good for 4wd on high traction surfaces
Monster Max (F310C) 1.17 Punch Control 30% Med/Low accelleration limiting - good for 2wd/4wd on med/high traction surfaces
Monster Max (F310C) 1.17 Punch Control 40% Med accelleration limiting - good for 2wd/4wd on med/high traction surfaces
Monster Max (F310C) 1.17 Punch Control 50% Med accelleration limiting - good for 2wd/4wd on med traction surfaces and offroad
Monster Max (F310C) 1.17 Punch Control 60% Med/High accelleration limiting - good for 2wd/4wd on med/low traction surfaces and offroad
Monster Max (F310C) 1.17 Punch Control 70% Med/High accelleration limiting - good for 2wd/4wd on med/low traction surfaces and offroad
Monster Max (F310C) 1.17 Punch Control 80% High accelleration limiting - good for 2wd/4wd on low traction surfaces and offroad
Monster Max (F310C) 1.17 Punch Control 90% High accelleration limiting - good for 2wd on low traction surfaces and offroad
Monster Max (F310C) 1.17 Punch Control 100% "High accelleration limiting - good for 2wd on low traction surfaces and offroad, very good setting for ""easy on parts"" style bashing."
Monster Max (F310C) 1.17 Brake Amount 10% The brake will engage at a strength 10% as strong as the strongest brake setting.
Monster Max (F310C) 1.17 Brake Amount 20% The brake will engage at a strength 20% as strong as the strongest brake setting.
Monster Max (F310C) 1.17 Brake Amount 25% The brake will engage at a strength 25% as strong as the strongest brake setting.
Monster Max (F310C) 1.17 Brake Amount 30% The brake will engage at a strength 30% as strong as the strongest brake setting.
Monster Max (F310C) 1.17 Brake Amount 40% The brake will engage at a strength 40% as strong as the strongest brake setting.
Monster Max (F310C) 1.17 Brake Amount 50% The brake will engage at a strength 50% as strong as the strongest brake setting.
Monster Max (F310C) 1.17 Brake Amount 60% The brake will engage at a strength 60% as strong as the strongest brake setting.
Monster Max (F310C) 1.17 Brake Amount 70% The brake will engage at a strength 70% as strong as the strongest brake setting.
Monster Max (F310C) 1.17 Brake Amount 75% The brake will engage at a strength 75% as strong as the strongest brake setting.
Monster Max (F310C) 1.17 Brake Amount 80% The brake will engage at a strength 80% as strong as the strongest brake setting.
Monster Max (F310C) 1.17 Brake Amount 90% The brake will engage at a strength 90% as strong as the strongest brake setting.
Monster Max (F310C) 1.17 Brake Amount 100% The brake will engage at full strength.
Monster Max (F310C) 1.17 Brake Amount MINIMUM na
Monster Max (F310C) 1.17 Brake Amount MAXIMUM na
Monster Max (F310C) 1.17 Brake Amount INCREMENT na
Monster Max (F310C) 1.17 Reverse Throttle 10% Reverse throttle will be 10% as strong as full throttle.
Monster Max (F310C) 1.17 Reverse Throttle 20% Reverse throttle will be 20% as strong as full throttle.
Monster Max (F310C) 1.17 Reverse Throttle 25% Reverse throttle will be 25% as strong as full throttle.
Monster Max (F310C) 1.17 Reverse Throttle 30% Reverse throttle will be 30% as strong as full throttle.
Monster Max (F310C) 1.17 Reverse Throttle 40% Reverse throttle will be 40% as strong as full throttle.
Monster Max (F310C) 1.17 Reverse Throttle 50% Reverse throttle will be 50% as strong as full throttle.
Monster Max (F310C) 1.17 Reverse Throttle 60% Reverse throttle will be 60% as strong as full throttle.
Monster Max (F310C) 1.17 Reverse Throttle 70% Reverse throttle will be 70% as strong as full throttle.
Monster Max (F310C) 1.17 Reverse Throttle 75% Reverse throttle will be 75% as strong as full throttle.
Monster Max (F310C) 1.17 Reverse Throttle 80% Reverse throttle will be 80% as strong as full throttle.
Monster Max (F310C) 1.17 Reverse Throttle 90% Reverse throttle will be 90% as strong as full throttle.
Monster Max (F310C) 1.17 Reverse Throttle 100% Reverse throttle will be 100% as strong as full throttle.
Monster Max (F310C) 1.17 Reverse Throttle MINIMUM na
Monster Max (F310C) 1.17 Reverse Throttle MAXIMUM na
Monster Max (F310C) 1.17 Reverse Throttle INCREMENT na
Monster Max (F310C) 1.17 TransmitterCalLabel Transmitter Calibration na
Monster Max (F310C) 1.17 MinCalLabel Full Reverse na
Monster Max (F310C) 1.17 MinCalLabel Tx Min Default na
Monster Max (F310C) 1.17 MidCalLabel Neutral na
Monster Max (F310C) 1.17 MidCalLabel Tx Mid Default na
Monster Max (F310C) 1.17 MaxCalLabel Full Forward na
Monster Max (F310C) 1.17 MaxCalLabel Tx Max Default na
Monster Max (F310C) 1.17 Throttle Dead Band Very Small (0.0250 ms) na
Monster Max (F310C) 1.17 Throttle Dead Band Very Small (0.0375 ms) na
Monster Max (F310C) 1.17 Throttle Dead Band Small (0.0500 ms) na
Monster Max (F310C) 1.17 Throttle Dead Band Small (0.0625 ms) na
Monster Max (F310C) 1.17 Throttle Dead Band Small (0.0750 ms) na
Monster Max (F310C) 1.17 Throttle Dead Band Average (0.0875 ms) na
Monster Max (F310C) 1.17 Throttle Dead Band Average (0.1000 ms) na
Monster Max (F310C) 1.17 Throttle Dead Band Average (0.1125 ms) na
Monster Max (F310C) 1.17 Throttle Dead Band Large (0.1250 ms) na
Monster Max (F310C) 1.17 Throttle Dead Band Large (0.1500 ms) na
Monster Max (F310C) 1.17 Motor Type Brushless Use this setting to run any brushless (3 motor wires) motor.
Monster Max (F310C) 1.17 Motor Type Brushed Reversing Use this setting to run any brushed motor, and have access to reverse.
Monster Max (F310C) 1.17 Motor Type Brushed High-Power Use this setting to run a brushed motor in foreward and brake only mode for racing.
Monster Max (F310C) 1.17 Arming Time 1 second Wait for 1 second of neutral throttle before arming.
Monster Max (F310C) 1.17 Arming Time 1.5 seconds Wait for 1.5 seconds of neutral throttle before arming.
Monster Max (F310C) 1.17 Arming Time 2 seconds Wait for 2 seconds of neutral throttle before arming.
Monster Max (F310C) 1.17 Arming Time 2.5 seconds Wait for 2.5 seconds of neutral throttle before arming.
Monster Max (F310C) 1.17 Arming Time 3 seconds Wait for 3 seconds of neutral throttle before arming.
Monster Max (F310C) 1.17 Arming Time 4 seconds Wait for 4 seconds of neutral throttle before arming.
Monster Max (F310C) 1.17 Arming Time 5 seconds Wait for 5 seconds of neutral throttle before arming.
Monster Max (F310C) 1.17 Cutoff Voltage No Cutoff Best for racing with top quality discharge NiMH or NiCad packs. DO NOT USE this setting with Lipo packs
Monster Max (F310C) 1.17 Cutoff Voltage 5.0V Use when running a battery pack with 7 or more NiCD or NiMH cells.
Monster Max (F310C) 1.17 Cutoff Voltage 6.0V Use when running a 2 cell LiPo battery pack.
Monster Max (F310C) 1.17 Cutoff Voltage 9.0V Use when running a 3 cell LiPo battery pack.
Monster Max (F310C) 1.17 Cutoff Voltage 12.0V Use when running a 4 cell LiPo battery pack.
Monster Max (F310C) 1.17 Cutoff Voltage Auto Li-Po Use this for all applications where you are using Lipo batteries. When selected, the controller will detect the number of Lithium Polymer cells in series in your battery pack, and set the cut off voltage to 3 volts per cell. When you plug the battery pack into the controller, after the initialization tones the controller will flash and beep the number cells it counted, so you can confirm the controller setting. If the cell count is incorrect, make sure your batteries are charged and the correct cell count is flashed BEFORE flying. Note: Do not use Auto Lipo with NiMH or NiCad cells.
Monster Max (F310C) 1.17 Motor Timing Lowest (0) Best for bashing
Monster Max (F310C) 1.17 Motor Timing Low (5) Good for bashing, and racing with the fastest motors
Monster Max (F310C) 1.17 Motor Timing Normal (10) Good for bashing or racing, with most any motor
Monster Max (F310C) 1.17 Motor Timing High (15) Be careful about motor heat (max safe temp is 200F) when using this setting. High Kv motors will get very hot very fast
Monster Max (F310C) 1.17 Motor Timing Highest (20) Extreme caution necessary for almost any motor - be sure to check motor temps often.
Monster Max (F310C) 1.17 Motor Timing MINIMUM na
Monster Max (F310C) 1.17 Motor Timing MAXIMUM na
Monster Max (F310C) 1.17 Motor Timing INCREMENT na
DrKnow65
DrKnow65's Avatar
02.04.2008, 12:36 AM
Very nice choise of arms Duster. Good job lincpimp. Suppose I highjacked the thread with the gun stuff, sorry all.
Back to Castle stuff, am I reading this right that the Mamba Max software only goes to 4S?
killajb
killajb's Avatar
02.04.2008, 12:53 AM
I'm not sure if that firmware is shared with the MM also, but I expect the MMM to perform as specified up to 6s.
I've read where people are asking for higher voltage capability (up to 12s).. why? I just bought two 6s 3700mah packs on the cheap from United Hobbies (which work great by the way) but was still set back $270. Spending any more for batteries in my opinion would warrant buying a much costlier MGM or Shulze controller.
I think CC hit the nail on the head as far as price and performance. At 6s, overall system efficiency should be pretty good. I think a 6s 4000mah pack and the lowest kv motor in the line-up (~1550kv/v) would be enough to give you 15-minute main performance all day with no worries.
I know this is all considering that the system runs as expected. For $300, and say.. another $200 for a decent battery I think you have a viable switch from a nitro race set-up.
team3six
Just a guy with a box of crayon's
team3six's Avatar
02.04.2008, 01:04 AM
God, You guys kill me. I mean really! Most of you complain for month's on end about when the MMM is coming out, and then when it gets held back everyone suddenly has been electronics wizards and can build a 20s system already. and Then you crawl up Castle's butt because it is being held back? I have for one been really nice in letting you you know something straight from the horses mouth when I wasnt supposed to say a thing. As well as others on here. But it still wasnt good enough. Now your not satisfied enough with the power it can handle or produce so your conjuring up HV systems for it and questioning its design makeup based on a cheap O.S. motor for Duratrax!? Do any of you remember what the whole Evader cost with that O.S. Motor? That would explain it if you did remember. Sorry guys but alot of you are no better than then the one18th.com kids trying to make a 1/2lb RC do 100 on the street and make everyone believe that they never stripped a gear, blown a batter, or desatroyed a whole rc. How about all of you who are intrested in the MMM (And yes that is the name for it, just because your computer data says it, meant that they didnt have a reason to add the whole description) Anyways, just be patient and see what it does, or what it will do. Or dont and get over it. There is always a TEKIN forum you can start.
It's not just paint! It's an Attitude!
www.team3sixrc.com
jhautz
jhautz's Avatar
02.04.2008, 01:12 AM
to make it...
or break it...
Silent...But Deadly
team3six
team3six's Avatar
02.04.2008, 01:14 AM
Oops, did that make you mad,lol.
www.team3sixrc.com
