Torque -
03.20.2008, 03:41 PM
03.20.2008, 06:25 PM
the axi might not have enuff ooommmphh..
but that hobbycity one, it should do fine in the baja, just make sure ur mount is strong enuff
03.20.2008, 09:30 PM
The buggy itself is done. I would have to change it quit a bit to run that big motor. It is only 13 lbs rtr. I just need a better motor, and maybe more cells  I did change the gearing to 20/66 and the speed is very nice, but the motor no likey. It got hot pretty quick.  I'm not using a heat sink though. I will probably run this setup until the MMM comes out.  I think I can fit four more cells to run 8s2p a123 with my mega 22/45/2. I would like to get 20 minutes runtime at about 40mph. Oh, I talked to one of my buddies and he has a camera so I should get a video next week.
03.20.2008, 09:33 PM
Are you using 40 series rims in the front also ? Or just the back ?
03.20.2008, 09:36 PM
just the rear
03.22.2008, 05:50 PM
your saying your mega motor gets hot quickly? i just got a 22/30/1 for my revo. it weighs right around 8-9 lbs so how do you think that will do...? bluegrooveconcepts.com used the motor on a 16/36 gearing with 3s and it did great though. low temps and everything.
03.22.2008, 10:49 PM
no, the 9xl is getting rather hot. I'm not running the mega yet.
video -
03.28.2008, 12:22 AM
I got a short video today. It doesn't last very long as I blew the diff at the end of the run.  I was driving pretty stupidly  I switched to 20/66 gearing and am pretty happy with the speed, but I'm thinking of getting a kb45-10L. I had the data logger on this run and peaked at 1690 watts and 112 amps. I am running with an actual 5b tomorrow and I will get a better video of that. http://s283.photobucket.com/albums/k...t=DSCN6290.flv
03.28.2008, 01:00 AM
The KB45 10l is a bad (good?!) motor, much more powerful than the feigao xl motors. I have not tested my xl kb motors yet, but they should be potent to say the least!
Yip Yip Yip...
03.28.2008, 01:06 AM
It's just annoying they aren't 5mm shaft and normal hole spacing.
Yip Yip Yip...
03.28.2008, 12:57 AM
Awesome. Still needs more power though  . Can't wait to see it compared to a real baja.
Brushless Heavy Weight....
03.28.2008, 01:27 AM
That looks pretty sick... I hope that has enough ballz to beat the baja... a baja with 30.5cc engine is pretty fast and powerful... Hook us up with the video dude, good luck
Yip Yip Yip...
03.28.2008, 07:54 AM
I don't think i would ever be able to grind down the shaft well enough using that trick. I'd make a mess for sure.
03.28.2008, 08:04 AM
Honestly, it isn't that hard. You just have to go slowly up and down with the disc at an angle to the shaft and make sure that you have a pinion available to check the shafts size. Just don't do too much at a time and if its close to sliding on use a bit of sand paper or something similar to get the last little bit off.
