jfruge
05.13.2008, 12:25 PM
Originally Posted by jfruge View Post
Anyone order a bonded heatsink version? I still have yet to get an update from them on my order.
I will send them an email today.
Thanks,
I just got word.... Its now on the way!
"Mr. Fruge,
It has actually been shipped out this morning.
Thank You,
Chris Bernier
Shipping Dept.
Medusa Research, Inc.
John Fruge
Madera, CA
8ight pro buggy, RCPD Ultimate, 4s TP 5000, MM ESC , NEU 1512/3d, JR Z8800T
8ight pro buggy, RCPD Ultimate, 4s TP 5000, MM ESC , Medusa V2 36x50mm, JR Z8800T
Buzzsaw46
05.07.2008, 11:18 AM
I would say a 12-14t John. That sould give you a good range of speeds through the mid to upper 30's possibly into the low 40's
jfruge
05.07.2008, 01:09 PM
Thanks for the info. I should have these conversions going before too long. I just got a PM that the RCPD EL8 conversion kits I had on order shipped yesterday.
Fun Fun,
John Fruge
Madera, CA
Motor
xcellr8n
Motor - 05.08.2008, 10:59 PM
I just installed a medusa 36-60-1600 in my losi 8t about a week ago. I am running it on 4s 6000 pack. I do not have alot of experience with different motors but I was running a nemisis xlt motor before this. This motor has plenty of power and seems to have just as much torqe and speed if not more then the nemisis. Raced a 20 min main this past weekend and temps came in at 135/motor-114/esc-95/battery. I am liking this motor so far.
Tim
TexasSP
Something, anything, nothing
TexasSP's Avatar
05.08.2008, 11:06 PM
Any idea the weight on your 8T? Thanks for the review by the way.
www.cubicle101.com
xcellr8n
05.09.2008, 10:14 PM
Right at 11 lbs. I think it was 10 lbs 11 ozs. I will take some pics of my setup and some vids when I get a chance.
Tim
Maciolus
05.11.2008, 02:03 PM
I am preparing to convert HB Lightning Pro Evo buggy. I want to use MMM ESC, Medusa MR-036-060-XXXXV2-5 motor and A123 cells.
I think about lighter setup. My track is rather short. Buggy does not have to be ballistic. 10 min runtime is enough.
I want to use 6S1P A123 cells. 6 cells fit chassis nicely, are light and can be charged as one pack with my Hyperion. 1600kv motor will not need as much current as 2000kv. Around 30 k rpm was enough for me in my brushless 1/8 stadium truck. Moreover 4 pole motors like to be overgeared.
What do you think about this setup (1600kv, 6S1P A123, 31 680rpm)?
> HB L2PE + MMM + Medusa 60-1600 @ 6S A123
> HB LSP + MMM + Medusa 70-1600 @ 6S2P A123
> AE B44 + MM + Medusa 50-3300 @ 4S A123
> AE J82 + SW 5700 @ 2S LiPo
> AE TC5R + MM 6900 @ 2S LiPo
highflier
Emaxx- FLM wannabe
05.09.2008, 08:09 AM
This may sound stup[ic but I was having a similar problem and I was advised to gear up not down. It seemed to help.
Is the ESC running very cool. (that is why they advised me it may be geared to low)
Highflier
Mister-T
05.09.2008, 08:12 AM
ESC is running hot as well
Buzzsaw46
05.11.2008, 02:48 PM
With your goal to lighten the buggy, I wonder if a 36-50 motor woundn't be enough. Since your not going for incredible top speeds, or crazy long runtimes a 6s seems overkill to me as well.
Your plan sounds fine but seems contradictory to your goal.
I have a heavy mostly alloy HPI NMT(very close in size to an 1/8scale buggy) that does close to 50mph for 10 min on a Hacker C40-8L and 4s A123's.
My Emaxx does 42MPH through grass for close to 10min on 5s A123's and MR36-50-3300v2
I think you can meet your performance goals and reduce weight even further!
Maciolus
05.11.2008, 03:23 PM
I just can't belive these motors are so good ;)
By lighter setup I mean 6S1P not 5S2P or 6S2P :)
What do you suggest? 50-3300 @ 5S or 50-2200 @ 6S
Buzzsaw46
05.11.2008, 05:35 PM
Well just to make sure I was thinking right I just did two back to back runs on my E-maxx one with the Medusa 36-50-3300 and one with my Neu 1512/2.5D both on 5s A123. The Medusa was running a 15t pinion 68t spur, the Neu on a 24t pinion and 68t spur. Both setups show 33mph on the Top speed calc @scriptasylum.com.
Data from the medusa run.
Data from the Neu run.
As for driving the Medusa felt a touch faster and maybe a bit quicker off the line, the Neu felt like it had a bit more midrange torque, better for racing?? or too much maybe?
I plan to move the Medusa to my EMT now, still on 4s(fits the truck well) and this should be a nice setup I think, and kind of what I think I would do with an 1/8 scale buggy if I was going to race at less then ballistic speeds. I'll do some more swapping around and see how the Medusa does on 4s in the truggy.
I'll post back with some data later tonight.
Need to mod my motor mount for the Medusa, might not get to it tonight.
Maciolus
05.12.2008, 07:48 AM
Thanks!
WOW! Only 9A of average amp draw.
Buzzsaw46
05.12.2008, 02:56 PM
Originally Posted by Maciolus View Post
Thanks!
No problem! This was a comparison that I was very interested in myself. I was amazed that the two motors were so closely matched. But it does appear if you want to save weight go with a high quality smaller motor with higher Kv and gear down a bit.
The only thing I still worry about is weather or not the bearings will fail early with such high RPM (45+k). I have a few hours on it though and it runs as well as it ever did
Maciolus
05.13.2008, 03:56 AM
My other concern are motor temperatures. I think longer can and lower kv will run much cooler.
