asheck
01.15.2009, 11:16 PM
I have had 0 issues running my 60-2000 on 5 and 6s in my Erevo.Actually even with the same gearing it seems to run cooler on 5s then 4s.Perhaps the longer rotor could make you want to turn lower RPM's,but really the 37000 seems to be in the sweet spot for mine.
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
01.16.2009, 01:25 AM
It probably runs cooler due to not be full throttle as much.
pasan
I <3 RC
pasan's Avatar
01.16.2009, 01:40 AM
I would select the 2000kv for running on 6S. You'd still be within the operational limits of the motor, and I find that Medusas' sweet spot is between 35k and 45k rpm, at least thats when my 36-50-3300 really becomes lively. Also, when you're running 6S the current draw is less and as a result everything runs cooler anyway, same reason why you see a difference between 5S and 4S too; if you're pulling the same amount of wattage from both setups, the 5S setup will obviously have a lower current.
E-Revo - Mega ACn 22/45/1E MMM 6S
E-Maxx - Feigao 7XL MM 4S
AX10 RTR - Stock :D
Micro-T - Losi LiPo upgrade
Mini LST2 - Discarded. Useless POS.
1/8 Scale Baja Bug - Medusa 36-50-3300 eZrun 60A 3S
GHSTRCN
01.16.2009, 02:30 AM
Nice, thanks for the inputs guys. 36-80 2000kv on 5S (6S later)it is! I can't wait. I really hope to have everything by next monday. 60+mph truggy baby!!!
I'm such a noob, lol.
Sold Monster GT 8.0 - KB-45 8XL 1600kv, MMM, Zippy-R 5S 25C 4800mah LiPo, Spektrum DX 3.0
Rustler VXL - 3S 4900mah 20C Rhino Lipo, 2S Turnigy 5000mah 20C Lipo, DX 3.0
  Send a message via MSN to GHSTRCN
01.16.2009, 08:32 PM
I on the other hand am still undecided...
pinkpanda3310
pinkpanda3310's Avatar
01.17.2009, 09:01 AM
I wanted to know what gearing you guys would recommend. I've ordered a 3680 1600kv ( but the order has been delayed ) and plan to run 6s in a 3905. Still the stock spur so what pinion do i start with?
Unsullied_Spy
Unsullied_Spy's Avatar
01.17.2009, 09:19 AM
With the 80mm you could actually go to Mod1 Revo gearing as long as you get the spacing right. A 30T pinion and 54T spur should give you around 65 MPH but that's a huge pinion.
pinkpanda3310
01.17.2009, 09:24 AM
Would I need to run a huge pinion?
Unsullied_Spy
01.17.2009, 09:41 AM
If you keep the 32p gears, yes. What is the minimum distance between the motor shaft and the input shaft? If you can get that measurement you can use BrianG's gear diameter calc to figure out what Mod1 gears you can fit. You could use a smaller pinion with a Jato spur if you wanted, but you'll get more speed and tougher gears with Mod1.
highpowerhobby
01.18.2009, 10:42 AM
Where can I get heat sink for a medusa 36-60-2000?
Unsullied_Spy
01.18.2009, 11:08 AM
http://rc-monster.com/proddetail.php?prod=RCM01
You'll want the "L" clamp.
pasan
I <3 RC
pasan's Avatar
01.18.2009, 12:17 PM
Or there's the Novak 5412. That's what I use on both my motors. It's got fins big enough to mount fans on.
AX10 RTR - Stock :D
Unsullied_Spy
01.18.2009, 01:11 PM
It doesn't have a clamp on it though, MedUsa motors don't have their endbells screwed in and can possibly come loose after a hard enough hit.
pasan
I <3 RC
pasan's Avatar
01.18.2009, 01:38 PM
Never happened to mine while it was in the rustler, and I broke that thing so many times I had to convert it to FLM. But either way, his choice.
AX10 RTR - Stock :D
Superbasher
Superbasher's Avatar
01.18.2009, 01:53 PM
I'll be running a 70mm 2000kv in my E-Revo and running MOD1 gearing, so what you guys are saying is that it may not fit due to the spur/pinion gap? If thats the case then I'll look up a 40t spur and a little bit bigger pinion (I'm going to be running 4s and gearing for 40mph).
  Send a message via MSN to Superbasher
