Five-oh-joe
04.27.2008, 03:06 PM
Originally Posted by Buzzsaw46 View Post
Good luck Joe!! As you can see mine runs good, nice and cool! Feels alot like my FLM EXT on an OS.18. Not quite as good as the EXT with the ported S-25;) MambaMonster is ordered to resolve that.
Yes on the track lutach, I've cut down about probably 80-90 trees getting ready so far have another 60-70 left to get rid of, pesky little box elder trees.
Thanks! The battery is almost charged. I'll probably end up running it tonight since I'm going to see a movie in an hour with my bro and his wife. I should use high timing for the motor since it's a 4 pole, correct?
lutach
lutach's Avatar
04.27.2008, 04:02 PM
Start with medium timing and check temps.
Buzzsaw46
04.27.2008, 02:41 AM
I hope I can come up with a cool layout. I was thinking maybe just a bash park kind of deal, get a few dump truck loads of gravle and just pour piles around out in the back yard. LOL We'll see what happens.
Buzzsaw46
04.27.2008, 04:35 PM
Yep, thats what I did. Havent tried highest timing, no real need to push it any harder.
Mine is set for medium start power and high timing, works well on mine but start low and work your way up.
killermmn
killermmn's Avatar
04.27.2008, 06:00 PM
question about the medusa
do the 36 x 60 will fit my emaxx are not??
Buzzsaw46
04.27.2008, 07:16 PM
Yes, but you will need 5mm 32p pinions.
Five-oh-joe
04.27.2008, 08:20 PM
Ok, just got back from an approximate 15-20 minute run with the 4800 kv 50mm medusa V2 motor.
It's about 78 degrees out, sun was going down, and a relatively light breeze.
Model Setup:
-Rustler w/ RPM a-arms and swami bar (so maybe a tad heavier than a stock rustler due to the wheelie bar, which is a huge hunk of aluminum for the most part).
-Proline Road Rages all around
-Geared at 23/87 for a FDR of about 10.3:1 (by my speed calculator, it's about 35mph if voltage under load is about 7.4 volts)
-Battery was a Trinity 4500mah 2s lipo
-Full steel transmission (thank you RC-monster;)) and full ball bearings
Mamba Max setup:
-Custom timing, 12 degrees (in between normal and high)
-70% brake
-50% reverse
-Propotional throttle with reverse lockout
-Low start power
-0 punch control or drag brake
-6.2v cutoff
Results:
Motor temperature- 125F
Battery temperature- ~120F
ESC temperature (has a 5v Novak fan on it)- 98F
Overall impression:
This motor is EXACTLY what I've been looking for! It runs cool, it has plenty of torque, and it's super smooth. The truck just runs better overall, and this motor seems like it'll be perfect to run during the summer when temperatures hit high 80s and low 90s.
If anyone is considering one of the 50mm motors for a 1/10 truck like a Rustler, CRT .5, or anything else small, go for it! Well worth the money IMO.
In other news, I just ordered the FLM transmission (from, of course, Mike; now everything but the top gear is from RC-monster for the Rusty's tranny). The stock tranny looks like it's warping where the motor mounts.
Buzzsaw46
04.27.2008, 10:18 PM
Awesome Joe. Good to hear yours is performing well also!
Five-oh-joe
04.28.2008, 12:06 AM
Me too! LOL! I think it's just BEGGING to be geared up more though.... I fear the batteries are on their way out though with that temperature. Then again, they WERE in that stupid hard case that Trinity puts them in. I took 'em outta the case, and am considering just some shrink wrap. For now, I put them back in the case, since I don't want them shorting on anything by accident.
Buzzsaw46
04.28.2008, 12:55 AM
I wish I could find more deals on A123's I got my first 16 cells for $7.31ea, best I can find lately is around $12/cell.
Good lipos are too expensive to subject them to the sandblasting my trucks get, so the A123's are the way to go IMO. Tough to fit in some vehicles though.
I even converted my MQ SE to 2s 1100mah A123's this weekend the little 1100 cells are pretty sweet for the fact I can charge them @8.8a. I do feel the voltage drop from 2s 1500 lipos though so I either need to gear up or drop in a higher kv motor(medusa 28-xx).
Five-oh-joe
04.28.2008, 01:05 AM
I've considered A123s, but for me, I'd have to buy the charger too. Coupled with a 2s2p pack, I'd be far beyond broke at the moment... Oh well...
The lipo I have now isn't puffed at all, so I think it'll hang on in there. I'll try drilling the case for some cooling holes (without the lipo in there of course) and see if that helps.
Buzzsaw46
04.28.2008, 02:16 AM
I here ya, my last charger was bought just at the begining of the A123 craze so I bought one with the capability even though it took me over a year to try A123.
Five-oh-joe
04.28.2008, 12:40 PM
I just saw the Onyx series of Duratrax chargers....so maybe A123s aren't ruled out quite yet. The one I'm looking at is about 80 bucks street price, does 1-3 lipos/liFe/liion cells, or 1-8 Nimh (psh...inferior technology...lol!) cells. Charges at up to 7 amps too, which is a huge step above my outdated Vision Peak Ultra or whatever in lipo mode. My charger is getting kind of old .
I need a job first. I just got back from school. With the economy taking a nose dive, it may be another few weeks before I get a job.
Buzzsaw46
04.28.2008, 04:38 PM
Too be honest that onyx looks to be a bit limited in performance. http://www.slkelectronics.com/lipodapter/index.htm I've been thinking about one of these.
Five-oh-joe
04.28.2008, 05:59 PM
The Onyx 230? It looks like it's more than what I would need. The only down side is only 3s lipo/A123. So if I decide to step up to a Maxx or an 1/8 conversion (more along the lines of "when" actually- just can't afford it right now), then the charger would be obsolete.
Does the MRC 989 do A123s? That's a charger I've always drooled over ever since it came out....
I've seen the "dapter". It's a great idea, but it doesn't charge to 100% (which probably will extend the lifetime of the batteries), so that bugs me a bit. I would personally rather the batteries take in their full rated capacity as opposed to a fraction; especially if it's a larger pack (I mean, I am paying for all the capacity, so I might as well use it....lol).
