05.20.2008, 05:01 PM
BG is the Novak 25v 2700uf cap going to work on 6s or should do you have a link to a 35v cap... Anyone know which caps the MMM uses? I thank you
05.20.2008, 05:19 PM
6s right off the charger is 25.2v, so no. It'll work, but I don't think for long. Not to mention the EMF spikes when braking will exceed this by quite a bit. I believe the MMM uses 35v caps, which gives a little leeway, plus you never want to run a cap right at its working voltage. Also, that Novak cap has a pretty high rating for its size and I think would heat up quite a bit.
I would use several smaller 35v or 50v caps in parallel - something around 330uF-470uF each. Obviously, you'd need low-ESR caps, so look for the 105*C rating. eBay has them sometimes pretty cheap (don't know about the quality), or electronic supply places have them too, but they usually require a large order.
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
05.20.2008, 05:42 PM
What length of warranty do the MMM's come with? I won't be able to get mine up and going for probably another month as still require parts to get my buggy going
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
TexasSP
Something, anything, nothing
TexasSP's Avatar
05.20.2008, 09:55 PM
One whole year, can beat that with a stick! (or a whip)
www.cubicle101.com
pipeous
5th Scale Guy
pipeous's Avatar
05.21.2008, 07:06 AM
I think the failure rate is much higher. Eric locally. Killed one, and was testing his second Sunday at the track. He had to work and arrived late to race so wanted to test a few laps with his new monster after racing. I had to work that night and packed up after racing. As I was driving out I see Eric carrying his buggy to his car and he said he was allready showing signs of intermittant problems after a few minutes of running. Last I heard, he'd killed MMM #2 that day and waslooking for another MM to put in.
05.21.2008, 07:40 AM
finfin - I'm sure it will be fine - They wouldn't know they weren't all yours!
DRIFT_BUGGY
05.21.2008, 08:39 PM
So the ones that stuff up get the new BEC put in and sent back to the owner?
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
Electric Dave
05.21.2008, 08:46 PM
<Pure Speculation>
I wonder if Castle is regretting not running a wide beta program for the Monster like they did with the Mamba?
</Pure Speculation>
johnrobholmes
johnrobholmes's Avatar
05.22.2008, 12:05 AM
Even if they did run more beta testers, the batch of bad parts they received would probably have still caused issues.
---JRH---
Electric Dave
05.22.2008, 08:29 AM
The idea of running a beta is to catch problems with the product before it ships to the paying public. I have every confidence that Castle will (or maybe has) resolve (d) the issues but it leaves a very bad taste in your mouth. Lack of confidence in the product...until the Rev 2.0 units come out. Maybe not all of the first batch are bad or have a problem but who knows when a first batch MMM will die, maybe it will be in the first 5 minutes or maybe it will be as you round the last corner on your way to a victory...then it puffs and you DNF...not fun.
glassdoctor
TEAM FUSION
glassdoctor's Avatar
05.22.2008, 08:53 AM
I agree, if the issue is what we/they think it is.
Beta testing and product development has nothing to do with a bad component from a supplier.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
Dagger Thrasher
I have no idea what's going on
Dagger Thrasher's Avatar
05.22.2008, 09:00 AM
True...they could've beta-tested until the cows came home, and still received a roll of bad components on the first production run. Just bad luck really. It sounds like they did a LOT of testing on the MMM anyway to me, even if it was in-house. Castle aren't going to release such a hotly anticipated product without making sure the design's virtually flawless IMO.
johnrobholmes
My point is that they could not control the quality of part that is causing the issue. Beta or not, they are not the manufacturer for the problematic part. How many beta testers would it have taken to spot the QC issue? 100? 200? That would put them 400 units behind just to break even, 200 betas and 200 production for all of the testers. That is a LOT of money, and would cost more than fixing this issue on all of the originally produced ESCs- damn near cost as much as the original production run just to make the betas and pay the testers!
---JRH---
jhautz
jhautz's Avatar
05.22.2008, 09:32 AM
Yea but... they would have less annoyed customers right now. And could possibly have saved a TON of bad press on this new controller advertised as "bulletproof." How much is that worth? If you ask CC now I bet they would gladly trade 400 units to make this little problem as if it never happened.
I know that I'm not really loving the MMM Bingo game. I have mine installed and its running OK so far, but I certainly don't have much confidence that it will keep running. I still drag my old esc with me to the track every time I run it. You just never know when/if you are going to need it.
to make it...
or break it...
Silent...But Deadly
Electric Dave
05.22.2008, 09:30 AM
Have they said that the "problem" is a faulty component? Is there a way to ID that component in currently shipped units?
