drkros3
05.28.2008, 01:47 AM
it looks good man. cant wait to see it running.
BIG Update
MetalMan
MetalMan's Avatar
BIG Update - 06.07.2008, 07:49 PM
This buggy was finished a week ago, but I didn't have time to upload pics then since I was busy preparing for the 1/8 electric race in the JBRL electric series. But here it goes:
Here's an overall view without the battery/battery tray:
I took inspiration for the motor mount from Mike's line of motor mounts, but obviously my design isn't as good. It's completely functional, though!
And now, the revolutionary part of this kit in action:
That's the best place I could find to mount the brake servo. All it is is an upper deck mounted above the center diff/motor mount, that extends toward the rear, and is bent down after the motor mount to keep the CG of the added servo as low as possible.
Then you can see the MMM mounted. There's industrial strength Velcro under it, and a zip tie holds it down securely (although the Velcro alone would allow the MMM to hold the entire weight of the buggy).
And a view showing the not-so-low CG:
With refining it would definitely be possible to get the brake servo and ESC mounted directly on the chassis plate, but I didn't have the time or determination to do so.
MetalMan
MetalMan's Avatar
Then came the two-piece battery tray, including the spacer to offset it from the chassis (to clear the dirt guard) and the actual tray:
Open, demonstrating the ability to adjust for different battery lengths:
Showing the height adjustment capability:
With the top strap in place (notice the outer velcro on the height adjustment strap, more on that soon):
My favorite part, showing how the length adjustment strap actually helps secure the top strap!
Another complete view:
Complete "nude" view:
Overall CG view:
Cool:
Just over 8lbs fully RTR!
MetalMan
MetalMan's Avatar
06.07.2008, 07:57 PM
Since racing this buggy, I gotta say that so far it's working very well. I didn't have time to set up the mechanical and motor brakes properly, but they still worked flawlessly. Nothing on the buggy broke which was nice because I had no spares...
Only problems I had were when the switch turned off (my fault, and immediately after the race I cut the switch off), and two wing mount screws came out all the way (again, my fault since I didn't thread-lock them).
Although, I did have to run a lot of preload on the springs to keep the arms level, which is an indication that the springs were too soft. Indeed, I would have been much happier with stiffer springs, but they aren't yet available.
The rear end was very loose in corners, but the track also had a loose top surface since all the water had evaporated from the dirt. Also, better tire choice could have fixed this.
Steering is great on this buggy. On a certain u-turn on the track I was accidentally cutting other buggies off because it was taking the turn so sharply.
I definitely look forward to fine-tuning the handling, braking, and acceleration of this new buggy!
lutach
lutach's Avatar
06.07.2008, 09:21 PM
It looks awesome.
Edit: Try the following springs: http://www.amainhobbies.com/product_...ducts_id/12695. I have the one for the Hot Bodies LSP and they are awesome.
tc3_racer_001
tc3_racer_001's Avatar
06.07.2008, 11:15 PM
hi there, nice job! could you please show me how you mounted your reciever/antenna mount thingy... this is something i need to work out! thanks,
ryan :)
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
MetalMan
MetalMan's Avatar
06.08.2008, 12:34 AM
It looks awesome.
Any chance you can get the inner diameter at the top of the spring and at the bottom of the spring? The shocks on the SH buggy use springs with a larger innder diameter at top, and they taper to a smaller ID at bottom.
ryan :)
It is just a simple receiver mount:
http://www3.towerhobbies.com/cgi-bin...?&I=LX3355&P=7
This is my only Nomadio receiver, so there's velcro on the bottom of it, enabling me to quickly swap it between cars .
Thanks for the comments!
lutach
lutach's Avatar
06.08.2008, 10:22 AM
You got me there . Give Amain a call or send them an e-mail with the diameters you have.
TDC57
TDC57's Avatar
06.08.2008, 02:19 AM
WWooowww that looks great Metalman.. I see the mount worked out quite nice and it looks like you CG or good?. Great to hear nothing broke!.. And I do like the micro servo for the rear brake.. Did you end up hooking to your 3 channel??. What is your gearing? And do you know what that bad boy weights?? I thinking what 7.5lbs??
Looks great!..
Nothing!.. Hahahahaaa..
MetalMan
MetalMan's Avatar
06.08.2008, 02:58 AM
Looks great!..
The CG is decent, but because I wasn't able to fit the components on the floor of the chassis the CG could be better.
I did use the 3rd channel mixed in with the throttle to control the rear brake.
Check out the last picture . Just over 8lbs . Not bad for the first electric conversion to the SH buggy in the US .
Originally Posted by tom255 View Post
Wow nice conversion but I dont like battery box, becouse material is too weak, if it not polycarbonade otherwice it too fragile. I dont trust velcro tape too on front of battery box. Maybe when it fresh it will hold battery but in dirt and after copuple battery replacements it goes weaker
The material is 1/8" thick polycarbonate - it's very strong. This is my third time making a battery tray using similar methods of velcro mounting (and it's worked for the last YEAR), and it's gotten better each time I have made a battery tray. In racing last Sunday there were no problems with the battery even close to falling out.
Besides, dirt doesn't get in the velcro fibers. I don't get the buggy dirty without the battery in there, and when the battery is in there, the velcro straps are on, closing off the inner fibers from whatever might get on them.
tom255
tom255's Avatar
06.08.2008, 02:31 AM
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
06.28.2008, 06:03 AM
I just bought one of these buggies from the LHS . Mine is an LRP S8-BX RTR but I am going to pull the radio gear and motor and sell them. It came with a LRP Z.21R which is a nice motor and I had better sell it quickly or i'll be tempted to run it. I'll run it as nitro for a while with a different motor until I can fund the conversion to brushless. Expect some questions from me MetalMan.
MetalMan
MetalMan's Avatar
06.29.2008, 12:56 AM
Fine by me . Considering I have the only electric conversion of this buggy at least on the west U.S. coast .
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
06.29.2008, 06:38 AM
Went racing today and I loved the way this car took the jumps. It was so smooth. This is my first 1/8th buggy so the handling just made me go WOW. A little disappointed it wouldn't turn but that may have been due to my rear suspension being too soft. It was a bit of a shame I only ran one race though, stupid nitro.
MetalMan
MetalMan's Avatar
06.29.2008, 07:15 PM
1/8 buggies in general are awesome racing machines. I too really like the SH/LRP buggy. Mine jumps PERFECTLY at the local 1/10 indoor offroad track. It's so perfect I don't even correct the nose with throttle, I just let off as soon as it takes off.
