cdis
05.28.2008, 08:18 PM
I agree with you there skellyo. Unfortunately, I can't do more runs with 5s packs as I just took em apart to make 4s packs lol.
If you look at those graphs tho, the spikes are fairly uniform, and look at the lower spikes. The lower ones are much higher on average for the MM than for the MMM. It seems that it only pulls lots of power when its at full throttle.
I did do a few extra runs at the track the day is was doing the graphs, but I was all over the place and didn't want to risk my DPR incase it was damaged when I flipped the car over or something :D
I'm sure some other people must have compared the 2 ESC's so maybe they'll chuck their data up for everyone as well. I just wanted to see if those results were to be expected by people or not, is all.
skellyo
skellyo's Avatar
05.28.2008, 10:36 PM
Just repeat the tests about 4 or 5 times with the 4S packs. That'll work.
cdis
05.29.2008, 12:08 AM
Yep shall do, as soon as it stops raining... :D
Location??
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Location?? - 05.29.2008, 03:22 AM
I hope your not in Scotland or England, it never stops raining up there.
cdis
05.29.2008, 03:54 AM
Hahaha, thankfully no :D Brisbane, Australia! :D We've had 3 weeks of sun, and today was the first rainy day :( terrible lol
nativepaul
nativepaul's Avatar
05.29.2008, 05:29 AM
Hey! It's nice an sunny here today, not a rain cloud in sight, having said that I do waterproof all my electronics so that I can run through puddles and in the rain without any worries.
Xray XT8, 1518, MMM, 4s5Ah.
Lots of boats.
fastelectrics.net
1maxdude
07.05.2008, 05:45 PM
Anyone think its his motor wire extension?
cdis
07.05.2008, 06:40 PM
Well it is rather long :(. Almost 20cm. I had a thought when I was making the extensions that the extra length might increase resistance and therefore amp draw, but the MMM wires were so long and phat, I figured it was negligible.
Did I make a boo boo? :D
azjc
07.05.2008, 06:51 PM
I had to do the same thing(extended my wires about 3" and use the 6.5mm connectors) I dont have a control to compare to but considering the power and wire size I am working with I dont think its an issue
auto2
07.06.2008, 12:56 PM
just curious if you tried a lipo battery as a comparission to the a123? certanlly for racing?
Science & Engineering :)
GriffinRU
Science & Engineering :) - 07.11.2008, 05:14 PM
There is a difference in total Fet's Rdon between MM and MMM, but such drop (60A vs 85A) I would relate to power connectors. Unless battery and motor wires were soldered in both cases.
Simplified calc, due to similar (close to be identical) setup:
16V/60A=0.267Ohms
16V/85A=0.188Ohms
0.267Ohms-0.188Ohms=0.079Ohms -> too high value for Fet's difference (5 vs 6 Fet's, even if only one is good). While 10-30mOhms for connectors is normal.
Temperature wise both ESC's and motor were close to each other, right?
