coolhandcountry
coolhandcountry's Avatar
09.29.2005, 10:11 PM
I do. http://www.rc-monster.com/forum/sho...15&pagenumber=1
search threw the thread. It has some on there. It shows it in the early stages. I have some of the skids to. I run the back gmaxx extension. The front was made. It takes the 100.5 ue dogbone just like the back. If you buy the back top extension plate will give you the exact length you need for front top. use it as a template. I beat a rear skid flat then trimmed it down for the front.
If you give me long enough. I can give you a weight on a monster gt. I putting a emaxx tranny on it.
nitrostarter
nitrostarter's Avatar
09.29.2005, 10:32 PM
I saw a used racebomb for $75 with the braces and all, I thought about picking that one up. But I decided G-Maxx would be my next choice.
N. Rustler conversion
MaxxBashers
10.01.2005, 12:24 AM
That is a good price. I got my torpedo for $45 shipped so I couldn't pass it up. Will use it for now until I save up for the G-maxx and talk coolhandcountry into showing me how to extend it... LOL. I just like a longer truck. I have almost got this together and just figuring out all the wiring and placement. I need to order some g-maxx battery straps from Mike. That is the only thing the torpedo didn't come with is the battery holders.
  Send a message via Yahoo to MaxxBashers
MaxxBashers
10.01.2005, 02:43 PM
Here are a couple pics of where I am at. I still have to install my rpm towers, new skids, run all the wiring and figure out what tooth pinion to order. My Warrior came with the heat shrink removed. Is electical tape ok to wrap it back with and is there anything I'm missing that you guys see?
MetalMan
MetalMan's Avatar
10.01.2005, 03:34 PM
Electrical tape should be fine to use, but make sure that the heatsink can breathe. I noticed that you have Tamiya connectors on your batteries! Those MUST go!
Sneeck
RC-Monster Custom
Sneeck's Avatar
Use heatshrink. I wouldn't use tape since that will get loose after time and trap debry on the loose tape survice since it's still sticky. But if you do wrap it in heatshrink, make some space for the heatsink.
  Send a message via MSN to Sneeck
MaxxBashers
10.01.2005, 03:36 PM
I have the deans plugs, just haven't swapped them over yet. I will try and find some heat shrink to use on it.
squeeforever
squeeforever's Avatar
10.01.2005, 04:10 PM
also, not sure if you know it but your black bec jumper is missing or not on there.
MaxxBashers
10.01.2005, 04:24 PM
yeah, I did notice that... Can someone please explain to me what it is for? I have read on here several people asking about its location to add or remove the jumper, but can't find anywhere that tells me exactly what it is or what the difference is with it off or on. Also does anyone have a pic of their 9920 wired? I read the description Mike put up, but I'm a visual guy. I need to SEE it to understand it.
squeeforever
10.01.2005, 04:35 PM
with the bec jumper off you will have to run a reciever pack or a ubec because when removed it disables the bec thus letting you use a external source to power the servos.
MaxxBashers
10.01.2005, 04:55 PM
ok, that is what I wanted to do anyway. Now I just need a pic of one wired up. LOL
squeeforever
10.01.2005, 05:05 PM
here ya go.....
MaxxBashers
10.01.2005, 05:09 PM
Perfect, THANKS!!! Now I can wire this thing up and get it going.
cabking
10.01.2005, 06:14 PM
MORE VOLTS :D
You can cram a few more cells on that chassis
see :D
squeeforever
10.01.2005, 07:29 PM
cabking, what rims are those? are they aluminum?
