07.09.2008, 08:17 AM
22T pinion with 66T spur should be fine (iirc = if i recall correctly)
You should also look at the inner diff cups - Looks like mike doesn't sell them.
Arms are fine - you will need this http://www.rc-monster.com/proddetail...rod=RCM03idler
07.09.2008, 10:57 AM
The RDlogistics internal diff cases are cheap - $30 for 2 or Mike has the FLM ones for $30 each if you want to go that route.
I would skip the RPM arms - Just go for the traxxas extended rears - I find the RPM ones too flexible.
If you have the strobe slipper at the moment I assume you are mod 1 - Use Briang's script to check pinion sizes once you decide on a motor.
On the Hardened Idler - If you are single speed you will only need one - I recommend the single speed mod.
It might be worth looking at the medusa 60mm - People are finding the run cooler and with the heatsink and the cost of this beast you may just spend the extra $20.
Also you don't need to go as expensive on the charger - I think you might want to re-look at the 1210i which mike stocks - You can charge both packs together with a Y lead and every once in a while charge separatly to balance them.
This saves you $100 which could allow you to buy a Neu motor - A 1515 2.5DF would be perfect and a much better investment in my opinion.
Rgds
Hardstyle
Hardstyle's Avatar
07.09.2008, 02:38 PM
Ok. So the external diff case is useable with the FLM internal case?
Ok. Only rears?
Yes, Mod1. I will check that script
Yes, the gearbox is singlespeed, I think. But I think that last owner has replaced the Hardened Idler.. Have to check that tomorrow
Is that motor 4 poler? BK12020 won't run it nicely?
Does the charging times suffer with this kind of modding? And this 1210i has integrated balancer?
This motor/esc setup is just temporary, I will look the mmm + neu set later... when they publish it...
Sorry for the huge quote
07.09.2008, 03:02 PM
Check with Mike on the diff cases but I believe yes.
Go with the:
- traxxas extended rear revo arms http://www.rc-monster.com/proddetail.php?prod=TRX5333R
- RP front arms (only if using stock plastic drive shafts)
Best confirm about the BK and Medusa compatability in brushless section I'm not sure
610i It has a lower power rating 250w but at 25V this is still 10a which is enough for a 2p pack - It has a built in balancer for when you do an occasional balance charge
http://b-p-p.com/proddetail.php?prod=fb_0610i
The 1210 requires an LBA10 external balancer.
07.09.2008, 03:08 PM
PS at the BK site it references that it should work on a 4 pole up to 50k rpm - I'm sre what this means practically though
Hardstyle
Hardstyle's Avatar
07.10.2008, 02:26 AM
I think I go with the basic 09XL motor for now. There shouldn't be any problems then and they are rather cheap. Don't get me wrong the motor/esc will change as soon as castle release the mmm combo..
I used Briang's parameter solver for the pinion and it pointed some around 20t pinion. Not quite sure If I typed all correctly though..
Differential Ratio: 2.8461538461538463
Transmission Ratio: 1.7222222222222223
Additional Ratio: 1
Spur Tooth Count: 51
Pinion Tooth Count: 20.7831
Battery Voltage: 19.8
Motor KV: 1853
Tire Diameter (inches): 5.51
Top Speed (MPH): 50
So you think the 610i with Y-lead would be enough for the A123 packs?
Ok, so let's look that list again
  • Charger - 610i
  • Mod 1 Pinions 18,20 & 22T
  • Traxxas extended rear & front revo arms (Steel drive shafts)
  • 09XL
  • Rc-Monster Heat Sink, Black
  • 2x Ofna spurs For Strobe Slipper
  • 2x 6S A123 packs 19.8V 4600 mah
  • External Diff case + (FLM) Inner Case
I opened the gearbox
It seems that the Hardened Idler is there? Should there be grease inside?
ID:	4960   Click image for larger version
07.10.2008, 01:56 PM
Looks great - That should work great - Yes there should be a V light coating of grease Honda Moly 60 works well.
Agree on gearing with tire balooning I think you might want to consider 16 18 20
Hardstyle
Hardstyle's Avatar
07.10.2008, 02:12 PM
OK, Thanks. Tomorrow I will email Mike the list. And ask at the same time about those outer/inner diffs.. Probably have to ask Mike to do the Y-Lead to the charger too.
07.10.2008, 02:35 PM
It is just this - you will need one anyway to connect the two packs into your esc...
Hardstyle
Hardstyle's Avatar
07.11.2008, 12:20 AM
Bk12020 has two sets of wires (black/red) so it will work in parallel when I just plug the packs to them. But anyway the charger needs the Y-lead.
Is there anywhere some more info about A123 batterys? just want to know the basic things..
Hardstyle
Hardstyle's Avatar
07.12.2008, 06:02 AM
I shot an email to Mike two days ago about the stuffs. But haven't got an answer. Should I spam another?
Just that im leaving end of this month to lapland and want to take the car with me. So there is pretty short deadline. Should I be worried, is Mike fast on shipping things to europe?
07.12.2008, 04:35 PM
He is very fast with shipping, probably just busy with orders and such as per usual. Give it another day or two, then email him again as a reminder. For basic A123 info, try my FAQ on my website: http://robotwars.00server.com/emaxxfaq.html and scroll down to the battery section.
Hardstyle
Hardstyle's Avatar
07.13.2008, 04:13 AM
Thanks, Bookmarked the site.
Hardstyle
Hardstyle's Avatar
07.24.2008, 10:32 AM
Ok the order is in progress, I think.. but still have to work out the payment with Mike..
Now I started to wonder about the motor, will 9xl be too hot with 19.8 volts? What you guys think?
Hardstyle
Hardstyle's Avatar
08.20.2008, 03:16 AM
Little update. Mike lost all my emails so the order did delayed a little bit . It happens, but I think he can get the stuff coming in a few days..
I did some preliminary work and turned around the gear box, installed front/rear bumbers, put the servo in place and loctited all the metal to metal screws. Also I ordered new Spektrum Dx3r radios should be here in couple days.. Cant wait
Can anybody say about the motor, should I consider 10xl beside 9xl?
Here some crappy pics:
ID:	5290   Click image for larger version
ID:	5291   Click image for larger version
