VintageMA
VintageMA's Avatar
07.15.2008, 02:25 PM
Hey - come on - anything is possible.
Only things I am waiting on before I get back into nitro is electronic ignition, variable valve timing, 4-stroke engine, with self-tuning on board processor. I'd add direct injection fuel system but I dont want to push it too far.
“Everyone has a right to be stupid; some people just abuse the privilege.”
auto2
07.15.2008, 02:29 PM
ok but only in a full tube chassis. besides you would win every race cause at 45 pounds you could crush all the other cars.
i like the cow girl thing. ye ha!!!!!!
jayjay283
jayjay283's Avatar
07.15.2008, 05:27 PM
Each monster max should be secured in a japanese beetle cage and come with its own radiator, pump and copper tubing LINK
and perhaps a light cool misting option for inbetween races to freshen up the sparkles on the ©Monster Paris Hilton edition rhinestone case® .
VintageMA
VintageMA's Avatar
07.15.2008, 06:38 PM
That cooling system is really cool - I sent them an e-mail to get more info of the viability and ruggedness of the system in an off-road vehicle.
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
07.15.2008, 06:41 PM
Pink Sparkle MMM
While were at it, why not chameleon paint
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
07.15.2008, 02:06 PM
Ok, while we're at it, how about a heatsink that's just a slab of aluminum with screw taps in it? Then, we can add any heatsink, heatpipe, liquid nitrogen setup we want.
bl-is-future
bl-is-future's Avatar
reverse cowgirl mounting. Now that is an ESC i want. I can see it now.
"THE ALL NEW MMM CASE! NOW INCLUDES YOUR VERY OWN COWGIRL. PERFECT FOR REVERSE COWGIRL MOUNTING!"
DRIFT_BUGGY
I got mine velcro'd down and then a zip tie around it
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
07.15.2008, 07:31 PM
I used super strong velcro to mount my MMM, only trouble is when I went to remove it the bottom half of the esc case stayed on the truck... :/
Now I have a ziptie around the case, and the velcro as before, works fine. I wouldnt mind mounting ears, but its no biggie to me personally- I just wouldnt mind a case that was the same as it is now, but minus the built in fan housing in the upper portion. Instead, have a flat area with a grill, so that a larger 30-40mm fan can be mounted ontop of the case. Maybe make it an optional case so that there is no warrenty issue with people not using a fan- buy the optional case and the warrenty is stricter or something.
George16
Supermaxx
George16's Avatar
07.16.2008, 01:35 AM
Funny you said that because the same thing happened to mine when I shrink-wrapped the rx wire.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
gixxer
gixxer's Avatar
07.16.2008, 03:00 AM
I like the idea of mounting tabs. I though my esc was secure until I took my e-revo to the track and it came out after messing up a triple.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
auto2
07.16.2008, 11:52 AM
yea seems the MM works with tape but the mmm is just one m too much for the tape..
azjc
07.16.2008, 01:37 PM
all I use is zip ties to secure the ESCs in my RCs and I have never had a problem
bl-is-future
07.16.2008, 01:38 PM
velcro on the base and then them velcro wire organizer straps to keep it all secure but yet easy to remove.
ogrfre01
07.21.2008, 07:56 AM
btw: is it possible to buy an extra case? (Just the casing)
