jayjay283
jayjay283's Avatar
08.08.2008, 02:51 PM
a 6s2p lipo from maxamps, 12 cells. Ill bet even on Maxamps best day 1 in 12 of their overpriced no name cells puffs. That pack will spend more time on a repair table then in the truck. JMO...
http://www.rclipos.com/ <~ the brands on there are enerland lipos (flightpower not listed but great lipos)
http://progressiverc.com/6S_Lipo.html <~ check out 6s lipos
http://www.readyheli.com/Kong_Power_.../kp-5025-6.htm kong power 6s
http://www.flydma.com/index.php?cPath=17_18<~ neuenergy lipos
bl-is-future
bl-is-future's Avatar
08.08.2008, 03:07 PM
Thunder power is listed and i was once told that thunder power and flight power are the same company.
jayjay283
jayjay283's Avatar
08.08.2008, 04:26 PM
Ive heard that also, I meant that Flightpower was absent from the list on that website for purchse of enerland options.
bl-is-future
08.09.2008, 10:04 AM
ic what you are saying now, yeah makes sense
Finnster
KillaHurtz
Finnster's Avatar
08.08.2008, 04:23 PM
out of curiosity, how much were you quoted for the big MA pack?
As already said, the "C" rating can be real BS at times depending on the company as there are no real stds. They are not necc lying, but they may be "optimistic."
The only way to really tell is to see discharge graphs and compare performance, as well as anecdotal reports. If a battery is getting hot during use, its pushed too hard.
If you want 60 mph out of a Muggy, then you are going to need a lot of power. I would plan on 2500-3000W peak or so. For 6S, this means about 120-150A peak. If a batt truely does 125A continous you will be fine. However, 3000W out a 1515 is going to start pushing the motor perhaps, esp on a hot wind like a 1Y. If you don't already have the motor, I may think about a 1521 even so you don't possibly overheat and/or use thegreater TQ to gear up and hit your spd goal. 60mph in a big MT is really really fast.
ReV:-O
RC-Monster Carbon Fibre
08.08.2008, 05:52 PM
thanks for all ur superb replys, i feel i am begining to learn... lol
the guy at maxamps quoted me $550 for the pack - which i am now not getting
heres a 62mph revo: http://www.youtube.com/watch?v=85v85Pn3DMk
ok, going by your advice i've made a new list of batteries
(i found all of these lipos at http://www.rclipos.com/RCL.html)
1:
Elite EL6S-5300 Li-Poly Battery In Stock $306.00
22.2V 5300mAh (6 cells) 30C/50C
Rating: 30C (159.0A) continuous, 50C (265.0A) burst
Dimension: 188mm x 46mm x 42mm
Weight: 800 grams
Termination: 10AWG wire leads
Request PQ / HP, AL or TP taps during checkout
2:
Poly RC PQ-6000XP-6S Li-Poly Battery In Stock $388.63
22.2V 6000mAh (6 cells) 25C/50C
Rating: 25C (150.0A) continuous, 50C (300.0A) burst Dimension: 165mm x 46mm x 64mm
Weight: 886 grams
Termination: Wire & PolyQuest/Hyperion tap
3:
http://www.impaktrc.com/product_info...oducts_id=2847
4:
PolyRC 6000 MAh 6S 22.2volt 25C pack
Cell Count: 6S - 22.2 volts.
Capacity: 6000mah
Pack Plug: None (You will need to add your own connector)
Tap Style: PolyQuest Style
High Performance Lipo pack
5:
PQ-5000XP 6S1P
Capacity : 5000mAh
Cell Model: PF 8643150XP
Voltage : 22.2V
Charge Current(2C) : 10.0A
Continous Dis.(25C) : 125.0A
Dimension(mm) : 54.0 * 46.5 * 166.5
Weight : 750g
6:
Thunder Power RC eXtreme 9000mAh 22.2V 6 Cell Li Poly 6s 9000 Lithium Polymer Battery
http://www.rctoys.com/rc-toys-and-pa...Y-BATTERY.html
7:
Thunder Power TP9000-6S2P Li-Poly Battery In Stock $599.99
22.2V 9000mAh (charge as 6 cells) eXtreme Series
Rating: 20C (180A) continuous, 50C (450A) burst
Dimension: 195mm x 48mm x 73mm
Weight: 1332 grams
Termination: Wire & Thunder Power taps
i particually like numbers 6 and 7 (i think they are the same) but i would have to buy a specific charger and balancer for the battery, as they seem to use their own brand. are thunder power related to thunder tiger, because i heard they wernt so great...
VintageMA
VintageMA's Avatar
08.09.2008, 12:28 AM
I highly recommend you check out www.rclipos.com. Good prices and great service and shipping. Use the code poly4me at checkout as a promo code and you will get 10% off your entire order.
If you are going to go for TP cell, make sure you go for the eXtreme V2 cells as they are the newest and highest rated. A 6S 5000mAh pack is $300. With discount above you could get for $270.
TP5000-6SXV
22.2V 6-Cell
726grams
50x45x160mm
$299.99
Honestly I would go for 2 or 3 or 4 or 5. I would not go for 6 or 7 as those are the original eXtreme V1 cells which are not as highly rated.
As far as I know Thunder Power and Thunder Tiger are not related - but I could be wrong. Would want someone else to confirm that one.
“Everyone has a right to be stupid; some people just abuse the privilege.”
lutach
lutach's Avatar
08.09.2008, 01:24 AM
On my BPP I went from 6S1P 5000mAh to 5S2P 7700 (2 5S 3850mAh) and 5S2P 9200mAh (2 5S 4600mAh) packs and I enjoy my nice long run times.
azjc
08.09.2008, 01:48 AM
1:
Weight: 800 grams
2:
Weight: 886 grams
3:
4:
Capacity: 6000mah
5:
PQ-5000XP 6S1P
Capacity : 5000mAh
Voltage : 22.2V
Weight : 750g
6:
7:
Weight: 1332 grams
options 6 an 7 both weigh 1.3kgs...way too heavy try to keep the weight around 750 grams, and for the price of the 9000mah 6s pack you could get 2 5000mah 6s Flghtpower packs and get more run time between the 2 packs...the heavier the truck is the more it will drain the pack
ReV:-O
08.09.2008, 07:22 PM
if i should get a 1521, which one should i get?
1521/1D 2900kv
1521/1.5D 1900kv
1521/1Y 1577kv
1521/2D 1425kv
1521/2.5D 1200kv
1521/1.5Y 1050kv
1521/2.5Y 630kv
1521/3Y 525kv
as you can see, all except the 1D have lower kv ratings, so they will be slower than the 1515/1y. i dont think it will be possible to achieve 60mph with a 1521
bdebde
That's All Folks!
bdebde's Avatar
08.09.2008, 07:49 PM
1521/1D 2900kv
1521/1.5D 1900kv
1521/1Y 1577kv
1521/2D 1425kv
1521/2.5D 1200kv
1521/1.5Y 1050kv
1521/2.5Y 630kv
1521/3Y 525kv
The 1521 1Y is popular for 6s, and I don't see why you think you won't achieve 60 mph on a 1521...
Differential Ratio: 4.09
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 20
Total Voltage: 22.2
Motor KV: 1577
Tire Diameter (inches): 5.8
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.008
Spur/Pinion Ratio: 2.3 : 1
Total Ratio: 9.407 : 1
Tire Circumference (inches): 18.22 inches (462.82 mm)
Total Motor Speed: 35009.4 RPM
Vehicle Speed: 64.22 mph (103.15 km/h)
Estimated Adjusted Speed: 59 mph (94 km/h) - 9% loss
Effective KV Value: 1577
KT constant: 0.86 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
Finnster
KillaHurtz
Finnster's Avatar
08.08.2008, 04:41 PM
BTW, the Zippy-H packs are supposed to be very very good packs at an awesome price. A number of airplane/heli guys claim they are enerland quality, but just not matched like you would get on a Neu, PQ, FP or other pack. They are too new to really know the long term stability of the packs, but for 1/3 the $, its hard to go wrong.
Zippy packs @ Hobby city
Zippy 6S 5000 mah (20C)
4800 25C
Or failing that, go 8S and less amps :)
1maxdude
08.09.2008, 05:48 AM
Sounds like Maxamps is the new Venom of lipos. Higher priced, lower quality, popular with the uninformed. Yeah, I was the one questioning the "hate" of maxamps. Your guys' applications are totally different and uncomparable to mine. Personally, my pack suits my needs so I'm not going to come in here and try to defend them and have this guy spend 550!!!???!! on their battery. Obviously, if you guys can get away with running 1p, then them trying to sell a 2p battery says something about them. Especially when its such a high capacity and they still want to go 2p.
08.09.2008, 10:54 PM
Maxamps lipos have their place, mainly 10th scale 2wd. About the only thing they sell that will work in a MT is the 8000 packs. They get rather heavy, and large, especially over 4s. I had alot of issues with defective cells, 10-12 packs... That alone would steer me away from MA, not to mention the outrageous prices, and"questionable" specs.
A 6s lipo may be too much for the 1515 1y, go with a 1521 motor, 1800-2000kv for 6s...
glassdoctor
TEAM FUSION
glassdoctor's Avatar
08.09.2008, 12:29 PM
I love my 12000mah pack LOL!!!!
You gotta see the face of the nitro guys when they hear how long my CRT can run on a charge... good stuff.
But I don't recommend a pack this big. I did it only for runtime.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
