JThiessen
JThiessen's Avatar
08.19.2008, 08:51 AM
I just up'ed my shock weight to 50K on the rears last night (still with the orange springs), and that seemed to help. But its not quite there - I'll have to buy the next step up in springs. NONE of my local LHS had any springs, or any of the P2 or P3 rockers. And one of them just laughed when I asked about the variable damping piston set (that store basically caters only to those that are just upgrading from Radio Shack).
Metallover
RC-Monster Spudgunner
Metallover's Avatar
08.19.2008, 11:04 AM
Sorry to just but in, but can you get different shock pistons with smaller or fewer holes? Or would that even help the problem?
JThiessen
JThiessen's Avatar
08.19.2008, 11:10 AM
Yes, you can. In fact the rebuild kit includes different config's of pistons. Its just a PIA to change them out. And, as was stated before, there are variable rate pistons that have a small spring tab over the hole.
Metallover
Metallover's Avatar
08.19.2008, 11:20 AM
Whoops. I need to touch up on my skimming...
I've never rebuilt any shocks before.. What is a good brand/weight of shock oil for a revo with a rtr weight of 7-9lbs?
JThiessen
JThiessen's Avatar
08.19.2008, 01:08 PM
7 to 9 lbs is a huge difference. If its 7 lbs (which I seriously doubt), then you should be down in the 20-30WT. Over that, and you will be up into the 50-60wt. Also depends on which spring you run.
Metallover
Metallover's Avatar
08.19.2008, 01:13 PM
I am converting a 2.5 to a direct drive outrunner setup. I took off every non-essential things. Right now it is 5 pounds without electronics. The electronics weight about two pounds and after trays etc it should be 7.5-8.
hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
08.24.2008, 06:10 PM
well, i thought i would add my set-up to the mix..
I run the VDP's(size 2). Traxxas sways(black) 60-65wt oil. "Green" front springs "Tan" back. Its running good so far, but I may step up the front springs a bit.
