Go Back   RC-Monster Forums > Support Forums > Novak
Maxxrickard
Maxxrickard's Avatar
05.11.2009, 02:08 PM
no it is not what their recommend. i have today 15/72. but i need moore speed.
http://www.teamnovak.com/products/br...ems/index.html
i think emaxx original is 68t. and they recommend 12t. so i think i will try 12/70. anybody that have used that gearing??
05.11.2009, 02:26 PM
12/70 is slower than 15/72 - The reason they choose the gearing is to avoid overheating - just gradually up the pinion and check for temp issues.
Maxxrickard
05.11.2009, 04:32 PM
is that true?bigger pinion is the trick!
thats bad i hav allready order 12/70...
05.11.2009, 04:34 PM
Well you said you wanted to go faster...
15/72 = 4.8 revs of motor for 1 rev of input shaft
12/70 = 5.8 revs of motor for 1 rev of input shaft
i,e, 4.8/5.8 i,e, 18% SLOWER!!!
Just think you can now run 15/70 = 4.666 revs of motor for 1 rev of input shaft
Should be about 3% faster if you can notice...
Maxxrickard
05.11.2009, 04:44 PM
in Novaks test is 12/68 faster than 14/68 is.
can i get moor speed in an other gearing than 15/70?
the temp is not a problem because i the esc have samr sort of temp protection
05.11.2009, 05:02 PM
They can still cook even with thermal protection - faster with lower gearing would imply over geared already i.e. motor can't spin faster.
A bit like driving in 5th gear up a hill if you drop down to 4th you can actually go quicker...
Basically you have too more options to try... 12/70 lower gearing to see if that was holding the car back or gear up and see if motor will take it with 15/70
Maxxrickard
i did send an email and change my spurgear to 66t
i will try 15/66
15/66=4.4
Maxxrickard
05.11.2009, 05:09 PM
i need my car to get quick not high topp speed!!!
05.11.2009, 05:24 PM
Gear DOWN for faster acceleration - gear UP for faster top speed...
when you said more speed I took as top end vs acceleration... 12/66 should still be ok...
Maxxrickard
05.11.2009, 05:34 PM
okey but if i just need acceleration?
12/66 gets the best acceleration and gets okey topp speed?
i like when the car makes wheelis..
05.11.2009, 05:41 PM
Try the 12/66 or buy a mmm and do backflips...
This is a Mamba Max on 4s with a 9XL
http://s168.photobucket.com/albums/u...urrent=018.flv
http://s168.photobucket.com/albums/u...urrent=017.flv
Maxxrickard
05.12.2009, 06:32 AM
i will not buy a new motor yet.
it was not possible to change my order so i will try 12/72 or 12/70. wich gearing give me the best acceleration?
you told me "Gear DOWN for faster acceleration - gear UP for faster top speed..."
it that the spur och pinion?
will a smaller pinion help me get better acceleration?
05.12.2009, 08:01 AM
Gear down means smaller pinion or bigger spur
Gear up mean bigger pinion or smaller spur
