Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
azjc
09.06.2008, 11:48 AM
What Im saying is if you ordered 14 cells and wired 8 of them in parallel that would give you 10,000mah and the other 6 would be wired in series to give you the 6s voltage. Im am missing something?
yes...you would need 8 cells for each 3.7 volt increase....
JeffEmbracedDC
JeffEmbracedDC's Avatar
09.06.2008, 12:58 PM
You wouldn't be able to hook those together..
you can't hook an 1s8p pack up to a 6s1p pack. That makes no sense..
Anything you hook up in parallel needs to be equal in voltage otherwise the lower voltage cells will likely explode.. and anything in series needs to be of similar MAH or you will drain the one faster than the other. So if you can't hook up yout 18 1s8p and 6s1p in series or parallel... how would you do it?.. you can't :(. You'd need 48 of those cells to make a 6s 10,000mah pack.
-Jeff
BL 8ight, BL FT B44, BL FT TC4, BL FT T4
  Send a message via Yahoo to JeffEmbracedDC Send a message via AIM to JeffEmbracedDC Send a message via MSN to JeffEmbracedDC
Takedown
WARNING: May become violent.
Takedown's Avatar
09.06.2008, 11:50 AM
Woah, I never knew this before. Well this idea is out the window... I feel like such a moron.
RIP- Tammy (9/14/08)
09.06.2008, 12:57 PM
Its ok, everyone has bad days!
You would need 6 sets of 8 cells wired in parallel to achieve a 10000mah 6s pack, so 48 cells total.
It would be a large pack, that is for sure! You could just buy 6 maxamps 10000 cells, but I could find better ways to spend 300 bucks....
