10.20.2008, 03:01 PM
Originally Posted by emaxxnitro
not if you are running high voltage! 2poles can take high voltage better than 4poles. Now 4 poles are better for 6s and under 2poles are going to have higher rpm
rpms causes destruction.. 4 and 6 pole motors make more torque and turn lower rpm. keeping them in below failure point, the added torque allows you to gear to compensate...
He is right multipole motors are better..at high voltage
10.20.2008, 06:50 PM
not if your motor is rated for it! the c50 comp is a 80000 rpm motor. and the 9xl can take up to 8s (my future bl plans)
10.20.2008, 08:26 PM
I don't know how you can say this. And I have to disagree with you on this as well.
Usually, pole count is determined by rotor diameter, not by voltage. Voltage doesn't really enter into the equations at all -- you can always change windings to make up for pole count difference (for example, a 2 turn 2 pole is the same torque as a 1 turn 4 pole...)
Patrick del Castillo
President, Principle Engineer
10.20.2008, 08:31 PM
I also think the 4 pole mentioned by Patrick will still have more torque being it has twice the magnet. Basically a 2 pole would be a 4 cylinder and a 4 pole would be 6 cylinder and 8 pole well would be 8 cylinder. Ever wonder why outrunners have more torque then our popular 4 pole inrunners?
10.21.2008, 01:01 AM
kt and kv are inversely proportional, so when kv decreases kt increases.
10.21.2008, 01:11 AM
We need sensored outrunners! I want CC to make a killer brushless crawler setup with a sensored outrunner and an matching esc with a built in switching bec that can handle 4s lipo. Had to throw that in, since it seems like Patrick is watching...
10.21.2008, 07:38 AM
Yes, but a 4 or 6 pole motor will have a higher Kt than a similar 2 pole with the same Kv.
10.21.2008, 09:09 PM
Did someone say outrunner? LOL
I for one can testify to the torque of the outrunner. In the experimental direct drive setups that I have built, a 12 pole outrunner with a low (600kv to 1000kv) has enough torque to shatter diffs and even bearings. I'm talking acceleration, not shock from jumping. They can also easily pull gearing that 2 pole motors will smoke over.
When considering torque, think about how many rotational degrees each phase shift is required to turn the armature, often times with close to the same amount of magnetic strength as a 2 pole.
Armature Diameter has a huge impact on torque. It's just a matter of leverage or distance from the magnetic force to the rotational center.
11.02.2008, 05:39 PM
I feel you pain, my old Turnigy 50-55B Would eat up diffs for lunch.
I would still like to see an addon, with adapter with a sensor pack. would definately be cool
10.21.2008, 01:44 PM
is there anyway to add a sensor kit to a motor??? i know its odd but imagine hollow spacer on the front of a motor, and an optical or some other type of sensor inside.. a sleve or magnetic ring on the motor shaft.. would definately be cool
I have no idea what's going on
10.21.2008, 08:00 PM
That's what I remember. I think he said he they were going to include a sensor port mainly for rock crawling on any sensored outrunners that might be released, just to help highly loaded startups.
10.21.2008, 09:03 PM
well now i need a new speed control as mine just shot two foot flames out...
10.21.2008, 09:10 PM
So Can I buy the Black CC NEU? Or is it going to be a combo only with the BL e revo?
I dont like the green motor, the black looks alot better IMO.
11.02.2008, 10:31 PM
Anyone?
Do we need a new thread?
RC-Monster Stainless Steel
11.03.2008, 01:05 AM
Anyone?
new thread needed
