10.30.2008, 01:05 AM
Originally Posted by TexasSP
If I spend 140+ on an rc motor it sure as hell won't be brushed.
You got that right!!!
I may have to get a dewalt 820 and run it on 5s lipo with a MMM. See how good it really is...
Anyone know how effecient they are?
10.30.2008, 11:30 AM
As per that robotwars wiki, about 81% for the old style can
http://www.robowars.org/wikka/DewaltDrivetrain
10.30.2008, 11:41 AM
Originally Posted by Oppressor
Thanks, I may have to give it a try then, that rating is not much worse than a feigao!!!
10.30.2008, 12:28 PM
Keep in mind though that efficiency will fall faster if they are run at lower voltage.
10.30.2008, 01:07 AM
You mean aside from the arcing and friction from the brushes?
10.30.2008, 01:13 AM
I think it has a built in fan... BrianG cryptonite there
You may be right, but it would be interesting to play with the "best" brushed has to offer, at least for 40 bucks...
BTW, I have the 6x6 maxx rolling now. Check the build thred!
10.30.2008, 01:16 AM
TBH, I'd use a fan if it was built into the motor, kind of like a Pletty. It's the add-on crap I'm dead-set against. Not only does it look retarded and messy, it shouldn't be needed. But if the fan was built-in, I'd see it as a little extra insurance against heat. And I hate heat more than I hate fans.
10.30.2008, 01:17 AM
Yeah, the plett fan is a really nice design. Makes the 1512 motor as capable as a 1515... I would rather not have the fan myself, but it does help alot on brushed motors.
10.30.2008, 07:59 PM
some sparks do fly, but these motors handle 24 volts well.
@lincpimp get one. If you want brushed, get the dewalt.
10.31.2008, 01:30 AM
I may still give the dewalt a try, but I think an outrunner will end up in the truck I am building. I have a 2826/12 axi that fits my gearing perfectly...
11.06.2008, 10:10 PM
Ok, so I got a dewalt motor out of an 18v drill. How do I go about removing the pinion? Looks like it is pressed on, but the gear appears to be on as far as the front bearing. I guess I can grind the gear off on each side to release it...
11.07.2008, 07:07 PM
Yeah, just grind off some teeth until the gear falls apart more or less, or grab a pinion-puller to remove it the 'proper' way... :P
11.07.2008, 11:46 PM
You could try heating up the pinion. The metals are probably not the same, so will have different expansion rates and may be easier to remove...
11.08.2008, 12:19 AM
I can try to heat it, but have no idea how to hold onto the gear. I could clamp it into the vice??? Then use a punch to tap the shaft out of the gear...
11.08.2008, 08:50 PM
If it was me, i would stay away from any treatment involving heat. It might undo the heat treatment that the shaft probably received hence weakening it.
